Steering Question - TCCoA Forums
post #1 of 3 (permalink) Old 06-07-2009, 07:25 PM Thread Starter
Steering Question
Does anybody know if the thunderbirds and cougars that have rack and pinion steering have two u-joints on the intermedaite shaft? I was told the crown vics have it but they do not they go right into a steering box with the rag joint. I thought someone might know if it has two or not(one that is attached to the rack and the other that would attach to the shaft coming through the firewall)? The reason I ask is I'm doing a 4.6 Mark VIII swap into a Mazda truck and know that the two u-joint shaft will bolt up to mine to clear the engine.
Thanx
johnboy2814 is offline
post #2 of 3 (permalink) Old 06-07-2009, 09:58 PM
These use 1 rag joint and 1 U joint at the column
post #3 of 3 (permalink) Old 06-08-2009, 03:05 PM
tbirdtess's Avatar
Sorry
Hello
Factory has one U-joint under dash + one rag joint under the hood.
Mine has 2 u-joints, one under dash & one under hood + A fire wall mount & a rag joint & a slide joint.
Steer Mod for Fox Manifolds
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
