Mark VIII Air Ride...What's wrong? - TCCoA Forums
post #1 of 7 (permalink) Old 06-22-2009, 09:39 PM Thread Starter
Send a message via AIM to Kaiser
I'll make this quick. The bags are new all around. The rest of the system is original as far as I know. The car drops the front or rear of the car when it is either sitting overnight or when I first start driving. It is not always. There are no small leaks. It drops all the way or none at all. This morning the front of the car dropped as I pulled out of the driveway. The pump timed out and the front didn't get back up, so I turned off the car, flipped the switch off and on, then started it up. The pump didn't run, so I parked it and drove my Bronco all day. I got home tonight and the rear of the car had dropped as well. I started the car and it fully aired up without a problem.
So what could it be? Solenoids? Ride height sensors? That's all I can think of...
Kaiser is offline
post #2 of 7 (permalink) Old 06-22-2009, 09:47 PM
Seems obvious to me that you are experencing a compressor failure. More exactly, a dump valve within the compressor. I suggest that you go to AmericanAirSuspension.com and read thru their trouble shooting chart.
BYE2YOU
growing old is inevitable
growing up is optional
94 SC
05 PT Cruiser GT Turbo Convert
Ken Horner is offline
post #3 of 7 (permalink) Old 06-23-2009, 05:52 AM
on the www.AmericanAirSuspension.com. Lots of good information (and parts) on that site.
69 F100 LWB w/460 Engine
post #4 of 7 (permalink) Old 06-23-2009, 07:39 PM
driller's Avatar
Sounds like the vent solenoid crapping out to me.
driller is offline
post #5 of 7 (permalink) Old 06-26-2009, 01:30 AM
see erik I told you the pump might be going out. Anyway isn't it great to have a site where your questions can get answered quickly.
FunktasticLucky is offline
post #6 of 7 (permalink) Old 06-27-2009, 10:19 PM Thread Starter
Thanks for the link! Sadly, I have symptoms of both a bad vent solenoid and a dying compressor. :-| I'll replace the solenoids first and see what happens. Those are very cheap. :-p
Kaiser is offline
post #7 of 7 (permalink) Old 06-28-2009, 12:58 AM
Damn that sux. I'd help you install that stuff but I won't be there till Dec/Jan Time frame. Maybe Wade can give you a hand if he is still there. When's he leaving for Basic anyway?
