Getting Ready to order some new shocks - TCCoA Forums
post #1 of 12 (permalink) Old 06-23-2009, 10:27 PM Thread Starter
missycougar's Avatar
Send a message via AIM to missycougar
I'm only interested in OEM Motorcraft parts and I am looking at Rock Auto's website but they list two different shocks -
MOTORCRAFT Part # ASHV14
XR-7; w/o Sport Option; 2 required per vehicle; Front
Applicable to the following cars:
FORD EXCURSION (2000 - 2005)
MERCURY COUGAR XR-7 1996
AND
MOTORCRAFT Part # AM589G {#F4SZ18124A}
FORD THUNDERBIRD LX (1994 - 1997)
MERCURY COUGAR XR-7 (1994 - 1997)
My gut feeling says to go with the second set since I don't think the Excursion and only the 96 Cougar shared shocks. In addition that Rock Auto part number doesn't show anything up in a search on TCCOA.
I also plan on getting new mounts as well. I'm only changing them out because the ride is like crap now...pretty sure I'm at 235k on the original shocks. Nothing else on the suspension appears to be worn out.
"I'd rather push a Ford than drive anything else."
Current Cars: 2008 Taurus X (84k) 1997 Lincoln Town Car (145k) - 1996 Mercury Cougar (260k)
Previous Cars:2003 Mazda 6 (160K) - 1990 Mercury Cougar (168k)- 1977 Lincoln Town Car (141k) 1996 Lincoln Mark VIII (116K) 1997 Lincoln Continental (212k) 2002 Mercury Mountaineer (92k)
missycougar is offline
post #2 of 12 (permalink) Old 06-24-2009, 12:48 AM
Traveler's Avatar
Well.. you might look into aftermarket, upgrade shocks... they can be very good. I love the KYB's I put on mine
If you're determined to get OEM Motorcraft... I agree with your gut.
BUT my concern is this.. if the shocks are all original... then the bushings, etc. are to most likely. And NO bushing will last for 235,000 miles... I'd give your bushings, and ball joints a serious look over. That could help explain the ride like crap.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 12 (permalink) Old 06-24-2009, 12:50 AM
If you go to www.motorcraft.com and enter your VIN, it should tell you exactly which shocks you need. Then you could order them from RockAuto, if you want.
post #4 of 12 (permalink) Old 06-24-2009, 09:40 AM Thread Starter
I've replaced the other suspension parts as they have worn, both upper control arms, tie rods, both lower ball joints and the strut rod bushings. But it is coming up in 100k miles on some of the parts I have replaced already.
However that being said, I was going to have everything checked out during the install.
My main reason for wanting Motorcraft is I want to maintain the factory ride, I don't have any interest in making it more "sporty". Do some of these aftermarket shocks offer as soft as a ride as the OEM?
post #5 of 12 (permalink) Old 06-24-2009, 09:46 AM Thread Starter
Go figure that www.motorcraft.com has the same part numbers listed as Rock Auto, as in they also show that the 96 Cougar and the Excursion share the same shock!
Part No: ASHV14
Desc: R Shock Absorber - Shocks & Struts
Manufacturer: MOTORCRAFT
Years: 96 - 05
Applications: 21
App Years Make Model Engine Qty Per Vehicle
2 96-96 MERCURY COUGAR All Engines 2
6 00-01 FORD TRUCK EXCURSION All Engines 2
3 02-02 FORD TRUCK EXCURSION All Engines 2
10 03-05 FORD TRUCK EXCURSION All Engines 2
However since it does show the other part numbers as well, I will purchase those.
Thanks for the motorcraft link, that can be useful!
post #6 of 12 (permalink) Old 06-24-2009, 10:03 AM
The excursion and cougar/bird do not share the same front shocks, that is definitely a mistake.
coolhandzep is offline
post #7 of 12 (permalink) Old 06-24-2009, 10:22 AM
Traveler's Avatar
No, but they could easily share the same rear shock. The rear shock design of our cars is fairly common, though I do have a hard time believing that the biggest SUV built would share the same valving(?) as the MN12
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #8 of 12 (permalink) Old 06-24-2009, 10:58 AM
I thought he was referring to the fronts... I forgot off hand how the rears are mounted on an Excursion however.
post #9 of 12 (permalink) Old 06-26-2009, 01:38 AM
just got with some tokico's or something... Sadly rear sport shocks aren' available anymore. You could always get the front sport shocks and then cobra IRS rear shocks... but I think aftermarket is the way to go.
FunktasticLucky is offline
post #10 of 12 (permalink) Old 06-26-2009, 01:47 AM
Traveler's Avatar
Originally Posted by missycougar View Post
.....My main reason for wanting Motorcraft is I want to maintain the factory ride, I don't have any interest in making it more "sporty". Do some of these aftermarket shocks offer as soft as a ride as the OEM?
She doesn't want anything "sporty". However, he is right, there are a number of quality aftermarket shocks out there now, that ride as nice as the factory units without costing an arm and a leg. Gabriel makes some good ones for example and I think you can find complete sets on Ebay.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #11 of 12 (permalink) Old 06-26-2009, 09:47 AM
Do people have some sort of aversion to walking into an auto parts store and asking for what they want at the parts counter? That would be the easiest way to get the stock-replacement shocks that you want, and most stores will get you the Motorcraft brand if that's what you want.
1994 Thunderbird LX 4.6 Modern Personal Luxury Coupe
1975 Elite 460 Vintage Personal Luxury Coupe
and a few GM products...
Lyanheart is offline
post #12 of 12 (permalink) Old 06-30-2009, 11:32 AM
motorcraft rear shocks are made by Monroe BTW, the markings and shock style are identical. The color and valving may be a bit different, that I don't know. Might as well get sensatrac, they replace them free when they crap out.
95 4.6L Rusty Survivor!
tbirdguy is offline
