front right suspension squeaking - TCCoA Forums
post #1 of 4 (permalink) Old 06-24-2009, 08:55 PM Thread Starter
Gl@re's Avatar
it just started the other day. what should i look for? when i lift the front right of the car it starts squeaking loudly. anyone have any ideas as to what it could be?
14.8 @ 95
post #2 of 4 (permalink) Old 06-24-2009, 09:08 PM
Ball joints (upper and lower) or sway bar endlinks are the first things I would check. Free play and cracked boots are bad signs. Also give all the bushings a good look, again, cracks and chunks missing are not good things to see.
post #3 of 4 (permalink) Old 06-26-2009, 09:10 AM Thread Starter
Gl@re's Avatar
well i went to take a look this morning, and the squeak has disappeared. i still checked everything out, and i don't see any missing chunks or anything. I really hope that the squeaking doesn't come back.
14.8 @ 95
post #4 of 4 (permalink) Old 07-07-2009, 07:00 PM
96tbirdboi's Avatar
that happened to me one time in my mustang the ball joints stopped squeaking then i pull into taco bell and the ball joint cracked
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
