Which stabilizer bar links to buy? - TCCoA Forums
post #1 of 13 (permalink) Old 07-03-2009, 06:23 PM Thread Starter
So I need some new stabilizer bar links and have been checking around locally, the only ones I can get here are TRW/Fed. Mogul, and they are $83 per side.
Rock auto has raybestos links for $12, but it will cost $29 to ship them to Canada..... lets not forget conversion.
I'm getting really uncomfortable driving around with my links in as bad a shape as I think they are, and I can feel the car "sway" from time to time, there is a LOT of knocking, and it pulls to the right if I let go of the wheel (which is not a habit i'm into, just for testing)
I would like to avoid spending a ton of money to replace these, but they need to be replaced, so any suggestions are welcome.
BigJohnny is offline
post #2 of 13 (permalink) Old 07-03-2009, 06:53 PM
I'm not for buying cheap parts, but sway bar links are not a critical safety part, I would probably go for those on a budget. Hell, people buy NO NAME stuff on ebay and seem ok with it. At least this has the raybestos/spicer pedigree, so I wouldn't say its garbage.
If you are not going to be doing racing or crazy cornering they will probably be fine. Also if you are planning to keep the car very long(over 5 years say), you may want to get something a bit better.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #3 of 13 (permalink) Old 07-03-2009, 08:05 PM
I bought a pair of Motorcrafts from Jon here at the parts counter for $43 a piece.
post #4 of 13 (permalink) Old 07-03-2009, 08:09 PM
I can only speak for Moog front stabilizer-bar end-links as I just replaced my worn-out ones with them. The old ones were knocking so bad when I bought my '97 T-Bird back in April that I took the car to a Goodyear dealer to have the front-end checked-out - I thought something was going to fall off! I've since replaced them with the Moog units and, so far, they are performing flawlessly! My front-end is totally quiet now and I'm very happy with them!
post #5 of 13 (permalink) Old 07-03-2009, 09:56 PM
The expensive aftermarket ones will have a grease fitting. As long as you keep them greased they will last a very long time. The others are sealed. When they wear out replace them, but they usually last a while so it is hard to say which way is better.
post #6 of 13 (permalink) Old 07-04-2009, 01:26 AM
FYI, worn endlinks won't cause your car to pull. Get your front end looked at, or check it out yourself. More than likely your tires are to blame for the pull.
coolhandzep is offline
post #7 of 13 (permalink) Old 07-04-2009, 10:42 AM
decipha's Avatar
or the strut rod bushings make sure you check those out
decipha is offline
post #8 of 13 (permalink) Old 07-06-2009, 07:11 AM Thread Starter
I could be crazy, but I think I see a little bit of positive camber on my front passenger wheel. Looks a little like my tires are also wearing on the outside edge a bit..... or on that wheel anyway.
am I incorrect in thinking that if my end links were bad, it has potential to throw off my alignment?
post #9 of 13 (permalink) Old 07-06-2009, 10:17 AM
Endlinks have no effect on your alignment specs. You could throw your sway bar/end links in the trash and nothing would be changed in terms of chamber, caster, or toe.
post #10 of 13 (permalink) Old 07-06-2009, 04:43 PM Thread Starter
ok, thats good to know then I guess
what's an alignment usually cost? I don't think they can be done in the garage huh.
post #11 of 13 (permalink) Old 07-06-2009, 05:05 PM
Nitemare's Avatar
My 94 has no end links, and it doesn't hurt anything. A few days after I got it, I was looking under it and found that someone cut them off with a torch. I do not know why.
I've seen four wheel alignments cost anywhere between $60 to a little over $100, depending on the shop. You can attempt to align it yourself, but it is not recommended. If it's off badly, I would eyeball it to something more acceptable temporarily, until I can get it aligned. But that's just me.
Needs more stall.
Nitemare is offline
post #12 of 13 (permalink) Old 07-06-2009, 06:07 PM
You are correct; not having sway-bar end-links on your '94 T-Bird doesn't hurt anything - EXCEPT the vehicle's handling (and, negatively, I might add)!!
post #13 of 13 (permalink) Old 07-07-2009, 02:28 AM
Nitemare's Avatar
It obviously will affect handling, but what I meant by that was that it won't hurt the vehicle (as long as you don't wreck the car). I figured what I meant was understood, but I guess I was wrong.
Needs more stall.
Nitemare is offline
