Front/Rear Spindle nut size - TCCoA Forums
post #1 of 12 (permalink) Old 07-06-2009, 03:20 PM Thread Starter
coggonobrien's Avatar
what size of socket do i need for the front and rear spindle nuts?
David
coggonobrien is offline
post #2 of 12 (permalink) Old 07-06-2009, 04:28 PM
girdnerg's Avatar
36 mm if memory serves.
girdnerg is offline
post #3 of 12 (permalink) Old 07-06-2009, 05:30 PM
your memory serves you well.
I recently did the drum to disc conversion and 36mm is the size needed.
the_doug is offline
post #4 of 12 (permalink) Old 07-06-2009, 06:14 PM
36 mm all around. You can rent the socket at AutoZone for a $20 deposit, which is refunded when you bring it back.
post #5 of 12 (permalink) Old 07-07-2009, 08:23 AM Thread Starter
standard or deep well?
post #6 of 12 (permalink) Old 07-07-2009, 08:37 AM
I think the only 36 mm sockets that are commonly available are labeled as "axle nut sockets", and those are deep wells.
post #7 of 12 (permalink) Old 07-07-2009, 09:57 PM
Advanced auto is selling these now, for much cheaper than I paid for mine, lol.
Grog6 is online now
post #8 of 12 (permalink) Old 07-08-2009, 08:56 PM
standard depth socket will work. sears has them.
do NOT reuse hub nuts. you should purchase a new one from Ford each time to remove them.
250 ft lbs of torque is a lot BTW.
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #9 of 12 (permalink) Old 07-08-2009, 09:22 PM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
yeah.... if youre a girl.
-John
MAMN-12 Fringe Member
94MN1246 is offline
post #10 of 12 (permalink) Old 07-08-2009, 09:24 PM
My torque wrench only went to 175 ft/lbs so I had to get them up to 200+ using a plain ol' 1/2 in driver and a breaker bar when I did it. Bent the darn thing in the process... it was a lot easier to do than I thought!
post #11 of 12 (permalink) Old 07-09-2009, 07:47 AM
94MN1246,
I was calling attention to the high torque value here....it might be one of the top 3 highest torque settings on the whole car. So thats a lot. Its a safety thing...trying to help a brother out who might not have a shop manual. Mine are re-torqued properly.
After 8 years of being on this site and its predecessors, thanks for reminding me why people leave and stop contributing useful info.
Bill H is offline
post #12 of 12 (permalink) Old 07-09-2009, 01:43 PM
Remember to torque, spin the wheel, torque, spin... Until it quits changing; Then take it the last bit.
And check it after a drive down the street; I checked mine everyday for a week...
Grog6 is online now
