Tools needed for job? - TCCoA Forums
post #1 of 4 (permalink) Old 07-16-2009, 09:58 AM Thread Starter
rotyp's Avatar
Question Tools needed for job?
I was wanting to know if anyone could tell me the size of the nuts on the upper and lower control arms. Any special tools, bigger wrenches, or anything of that nature that I might need to change my control arms, sway bar end links, shocks, struts, and inner and outer tie rod ends.
Thank you
1995 Cougar XR7 4.6
Mark 8 Tranny, 04 Maraduer TC, 93 Mark driveshaft, 180 tstat, 96 Sport Wheels, 3.73's /w T-Lok, X-Cal2 (by Lonnie) - SOLD
2007 Pontiac Grand Prix GT 3.8 S/C
rotyp is offline
post #2 of 4 (permalink) Old 07-16-2009, 10:08 AM
I know that an 18mm ratcheting boxed end wrench will make the upper control arms MUCH easier to R&R.
I can't remember the rest of them off the top of my head. Hopefully someone else will chime in.
69 F100 LWB w/460 Engine
post #3 of 4 (permalink) Old 07-16-2009, 10:39 AM
Here are a few tools off the top of my head...
hammer
21mm wrench/socket (lca to frame)
15mm wrench/socket (uca pinch bolt, sway bar endlink)
15/16" deep (i'm 90% certain that is the size of the nut on the strut rod behind the lca)
big crescent wrench (inner tie rod, just spin it off, don't bother monkeying with the rivet)
I don't remember the size of the nut on lower ball joint.
If you are gonna change the shocks I hope you have access to a wall-mounted spring compressor. I have done them without one, but didn't particularly enjoy it compared to the warm secure feeling of using a proper compressor. Good luck.
coolhandzep is offline
post #4 of 4 (permalink) Old 07-16-2009, 10:42 AM
you ought to search this forum a bit. i just posted that i think you need a 30 mm open end wrench for the strut rod nut. you are not alone, this job has been done before.
your going to need a ball joint puller to get the spindle off the LCA. get a good one from sears. the harbour freight crap broke on my first side, i had to go buy another.
i good socket set should have what you need for the rest. if you are still not sure, put it up on jack stands and get under there and check it all againt your toolset.
the list ought to be a sticky in this forum IMHO anyway
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
