Inner Tie Rod Ends - TCCoA Forums
post #1 of 7 (permalink) Old 07-20-2009, 03:08 PM Thread Starter
Inner Tie Rod Ends
O.K., how does one go about replacing the inner tie rods on a '97 T-Bird? Is there any reason it can't be done while the rack is installed on the car? I've searched these forums and looked in my Haynes manual and I'm still not sure! I replaced my upper control arms last Saturday and am going to replace my lower control arms, tension strut bushings and tie rod ends this coming Saturday. I figured that I should also replace the inner tir rods at the same time, but am unsure if I can do it or how to go about doing it.
Any help will be greatly appreciated!
post #2 of 7 (permalink) Old 07-20-2009, 04:40 PM
tbirdtess's Avatar
Inner tie
Hello
Yes, You can change the inner tie rods while still on car.
There is a rivet locking the nut in place. You may just turn with a big wrench to brake the rivet. I drilled 1 & broke 1 (rivets).
Paul
Make sure you check out the boot. They rip easy.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 7 (permalink) Old 07-20-2009, 05:03 PM
If the inners are wasted, I'd replace the rack, as it's probably pretty worn as well.
That's what I found when I was going to do mine, anyway. My play wasn't in the tie rods.
Changing the rack in a 4.6 is terrible, tho. If you're sure the rods are what has play, it might be easier to just change them out.
The next time I replace a rack on an MN12, the engine will be out, lol.
post #4 of 7 (permalink) Old 07-20-2009, 05:18 PM Thread Starter
I am only replacing the inner tie rods because I basically just want to rebuild my entire front-end - only because of the high mileage on the car, not because of any obviously worn parts! My T-Bird, which I bought about 4 months ago, has 147,000 miles on it. The front sway-bar end-links were COMPLETELY shot when I bought the car (TERRIBLE knocking & banging sounds when driving over bumps!), so I replaced both front sway-bar end-links, both front shocks/struts and both front coil springs (my driver's-side spring was broken). Other than that, my front suspension is now completely quiet and does not feel excessively loose.
However, due to the high mileage on the car and the fact I don't know how long any of those parts have been on the car (and, for my own peace of mind!), I want to replace ALL the rest of the front suspension parts (I'm going to do the rear suspension, too, after I do the front - I already replaced the rear shocks and rear sway-bar end-links) so I know everything is new. I replaced the upper control arms this past week and intend to do the LCA's, tension strut bushings (both at the arm and the frame) and tie rods (both inner & outer) this coming Saturday. I do not think the rack needs to be replaced - it steers fine and is not leaking.
I have never done either inner or outer tie rods on a car - the outers look very easy to do, but how hard are the inners? I see (by looking at pictures of new parts a napa.com) that inner tie rods come with a seperate nut and what looks like some type of rivet or pin. Does the nut go on the rack before you screw the inner tie rod on and does it act like a lock nut, like the outer tie rod has?
post #5 of 7 (permalink) Old 07-20-2009, 11:46 PM
if you buy a steering rack with the inners already on it youre getting the biggest bang for your buck. plus you get new bushings for the rack so dont forget about those. I paid 180 for new rack, inners and a set of rubber rack bushings.
post #6 of 7 (permalink) Old 07-20-2009, 11:50 PM Thread Starter
That's great! But, the only problem with that is that I do NOT want to go through the hassle of trying to change the steering rack on this car! I understand it's a REAL pain - at least, with the engine in the car!
Otherwise, I'd definitely do that!
post #7 of 7 (permalink) Old 07-21-2009, 01:12 PM
the steering rack isnt easy but if you use the little tool I used on accident the job isnt so bad. here is the thread I totally recommend this small wrench tool.
http://forums.tccoa.com/showthread.p...ring+rack+tool
