How do I tell which sway bar (size) I have? - TCCoA Forums
post #1 of 5 (permalink) Old 07-24-2009, 03:01 PM Thread Starter
Send a message via Yahoo to REDinLV
Hello!
I'm in the process of changing out my end links, UCAs, LCAs and outer tie rod ends; basically changing most everything up front. While I'm pulling everything out, I figured I'd also swap out the sway bar bushings. I realize however, that I have no clue what size the sway bars (front and rear) are!
I know it seems silly to not know, but I picked this car up from my father and never got the chance to ask him what's installed. I know he at least purchased aftermarket bars as I remember there being sway bars on the floor in his garage before I drove the car from Portland to Vegas, and I know he was fanatical about his suspension; I just don't know if the bars I left in Oregon were the aftermarket or stock ones.
My question: What's the easiest way to determine which bars I have installed? Or, more importantly, what size they are?
Thanks in advance! This forum rocks!
REDinLV is offline
post #2 of 5 (permalink) Old 07-24-2009, 03:42 PM
tbirdtess's Avatar
Bar size
Hello
according the the tech articles 1.06 front .94 rear. Both solid.
Paul
I have 1 3/8 front & .94 rear 90 t-bird circle track racer.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 5 (permalink) Old 07-24-2009, 04:01 PM Thread Starter
Originally Posted by tbirdtess View Post
Hello
Paul
Thanks for the information Paul. I had actually found the same article. However, I'm not sure whether or not have still have the stock sway bars installed. So, my question is, how do I tell which bars (size) are currently on the bird?
REDinLV is offline
post #4 of 5 (permalink) Old 07-24-2009, 04:38 PM
Measure them
post #5 of 5 (permalink) Old 07-24-2009, 11:47 PM Thread Starter
Measure them
That's what I figured, but I wasn't sure if there was maybe some sort of stamp or engraving I could look for. Looks like I'm using string and and a tape measure.
Thank you.
REDinLV is offline
