Replacement Struts for T Bird. What brand ? - TCCoA Forums
post #1 of 11 (permalink) Old 07-30-2009, 06:07 PM Thread Starter
Burbank 98 lsc's Avatar
I have Coil spring Conversion on my Lincoln and the front Struts are Garbage(too loose).
I am looking for replacement front struts but I want to upgrade to stiffer front Struts as I don't fill safe at speeds over 70 mph with those Struts.
Btw I have 03 Cobra Bilsteins in the Back and I love them.
So is there any replacement front struts (other than Koni or Supercoupe)) Which are little stiffer than stock Thunderbird Struts.
Thanks.
Black 98 Lincoln Mark VIII LSC [email protected] 128.16 mph
1998 Mark VIII collectors edition(SOLD)
2007 Mitsubishi Outlander V6(gas saver)
2006 Mercedes R500 4 Matic(family cruiser)
Burbank 98 lsc is offline
post #2 of 11 (permalink) Old 07-30-2009, 06:09 PM
T-Bird has no Struts it looks like it but the shock goes thru the spring
post #3 of 11 (permalink) Old 07-30-2009, 06:22 PM
Nomenclature aside and beside the obvious konis and extinct bilsteins, some people seem to like tokicos. The shock 'going through the spring' has nothing to do with its classification of either a shock or strut. I'm not about to be anal about the actual name of the part to a guy that has an 11 second mark, haha
coolhandzep is offline
post #4 of 11 (permalink) Old 07-30-2009, 07:53 PM
Dusty's Avatar
I am happy with the Tokico blues.
The Sport shocks seemed to be the choice for the front, but I don't think they are available any more.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #5 of 11 (permalink) Old 07-30-2009, 07:55 PM
x2 on the blues
post #6 of 11 (permalink) Old 07-30-2009, 09:09 PM
Monroe SensaTrac here. Definitely quite a bit noticeably stiffer than the stock setup, cheap enough, and easy as pie to put in. I've never had anything but those and the worn out originals though.
post #7 of 11 (permalink) Old 07-30-2009, 11:16 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
i use kyb gr2's and i love them they are probably the stiffest ones atleast from what i've been told for birds. i love the stiffness i do mountain road runs and it hugs turns and on the quick straights it stays nice and stable.
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #8 of 11 (permalink) Old 07-30-2009, 11:25 PM
Do you have any problem with front-end "float" over dips in the road on your T-Bird? I bought KYB GR-2's for mine back in April and I tried to install them. I couldn't do it myself due to the lower mounting bolt being seized to the bushing in the LCA. The shop I took it to get my front struts/shocks installed said my front driver's-side coil spring was broken, so I had them install the KYB's and Moog coil springs, but I haven't been happy since because my front-end bobs up and down just a bit more now than it did before I had that front-end work done. I'm hoping it's the Moog coil springs, especially since they're the same part number as for the 3.8 liter V-6 T-Birds (I have a 4.6 liter V-8). FYI - my car had the sport "JJJJ" springs.
I just got some Vogtland 3/4" drop coil springs today that I'm going to install this weekend - hope that helps!
I guess you're happy with those KYB's, huh?
post #9 of 11 (permalink) Old 07-31-2009, 12:52 AM
Clueless Poster
yeah why would they put the 3.8 springs on i assume you get wheel hop through high speed turns as well? i would suggest getting eibachs 1.5 lowering progressive springs for handling if you drag get the inert believe vogland makes the intert lowering springs.
i also had the sport suspension and kybs and eibachs really keep the sporty feel with the stiffer ride. my uncle prefers konis cause they are more "plush feeling"
but no i have no ride issues what so ever.
i <3 my kybs
post #10 of 11 (permalink) Old 07-31-2009, 01:00 AM
i <3 my kybs
They put the same springs on my car as for a 3.8 liter V-6 because Moog only makes ONE replacement coil spring for the T-Bird, and it's listed as fitting BOTH the 3.8 liter V-6 and the 4.6 liter V-8. It's the same for ALL replacement springs I've seen for T-Birds, with the exception of lowering or high-performance springs.
post #11 of 11 (permalink) Old 07-31-2009, 01:21 AM
Clueless Poster
yeah, you can get a set of eibachs for a decent price i paid i think 100 bucks shipped for my set from a forum member here. and i have to say never regret it they maybe used but they sure as hell handle better then the sport springs.
i'm sure someone has a set of em for sale.
