Bent Lower Control Arm Mounts - TCCoA Forums
post #1 of 9 (permalink) Old 08-12-2009, 11:52 PM Thread Starter
When i was looking under my car for any problems i found that the right rear lower control arm mounts were bent. even when examining the car from above you can see that it is bent. its pretty bad. is there anything i can do to fix this or have it fixed? thanks.
jonashaffer is offline
post #2 of 9 (permalink) Old 08-13-2009, 12:49 AM
Body shop
post #3 of 9 (permalink) Old 08-13-2009, 01:42 AM
DLF
DLF's Avatar
I have seen several that were slightly bent while installing new bushings. It happens if the car hits a curb hard enough (and often bends something else as well). If the rear mount brackets are "tweaked", then the forward mount brackets almost certainly have to be as well (assuming that the LCA was installed when it happened).
If the welds where the mount bracket attaches to the sub-frame, and the sub-frame itself appear to be straight, then I've used a 5 lb sledge to realign the mounts. Mind you, this is only if they're are "slightly" off, and YMMV.
All this needs to be done with the LCA's off of the car. The distance between the rear mount ears should be just slightly greater than 3.2" (the forward brackets are about 4.6" apart).
As long as nothing is really bent out of shape, and appears to be structurally sound, reinstalling the LCA will pull the brackets into position, and a 4-wheel alignment will make up for any slight variance.
If you think it's bad, than I'd certainly agree with the body shop suggestion.
My Web Site
DLF is offline
post #4 of 9 (permalink) Old 08-13-2009, 05:20 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Since all MN12 front k-members are the same, there are tons of them in junkyards. If it is bent very bad why not just replace it?
tinman_72 is offline
post #5 of 9 (permalink) Old 08-13-2009, 10:42 AM Thread Starter
thanks. ill probally try the hammering method at first and see how it works out.
post #6 of 9 (permalink) Old 08-18-2009, 02:41 PM
drag-aholic
BAGGED89's Avatar
that is also the place that hits the ground when the cars bottom out ( lays out as we do it). If this was the case you might see some scraps un the front IRS mount also.
1989 LX Full Air Suspension
BAGGED89 is offline
post #7 of 9 (permalink) Old 08-18-2009, 06:37 PM
94mncougar's Avatar
Send a message via AIM to 94mncougar
If you replace the K-Member, may want to consider a new rack-n-pinion while you're in there. . .
Stephen
Winter mods included:
- Developing Rocker Rust
- Saggy Suspension - fixed!
- Chipped paint
- I'm sure more to come... TOTALED
94mncougar is offline
post #8 of 9 (permalink) Old 08-18-2009, 07:59 PM
drag-aholic
BAGGED89's Avatar
am I missing something. I thought we were talking about the rear?
BAGGED89 is offline
post #9 of 9 (permalink) Old 08-21-2009, 09:31 PM
CrystalPistol's Avatar
Yeah ... me too.
Not sure after he metions "... even when examining the car from above ..."
CrystalPistol is offline
