Mark VIII Aluminum Rear LCA's - TCCoA Forums
post #1 of 14 (permalink) Old 09-15-2009, 11:22 PM Thread Starter
So, if someone had a set of Mark VIII aluminum rear LCA's that they wanted to put on a 1997 Thunderbird, where could they get new bushings to install in it? I heard that stock/stock-type bushings aren't available for these arms.
post #2 of 14 (permalink) Old 09-15-2009, 11:57 PM
mercury267's Avatar
I would have presumed that the t-bird LCA bushings and the Mark LCA bushings would have been the same? I got a set of LCA bushing for my t-bird last year. I believe (memory serving me correctly) from Supercoupe performance. you might want to look them up.
"Behold, I am coming quickly..." Rev. 22:12-13NKJV
- Jesus Christ
My 95 LX project car
mercury267 is offline
post #3 of 14 (permalink) Old 09-16-2009, 12:48 AM
Traveler's Avatar
Search search search....
I just did this swap a couple months ago. The bushings are very hard to find.. even stock rubber replacement bushings. I was in luck, the bushings in the Mark VIII LCA's were in better shape than the original stock bushings. That of course is for the INNER bushings...
The outer bushings are the same as the T-birds and you can get them (as has been stated) from SCP.
http://supercoupeperformance.com//Default.aspx
Its probably a good idea to check and replace the toe compensator links as well while you're doin the job.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 14 (permalink) Old 09-16-2009, 01:32 AM Thread Starter
Yeah, I had ALREADY checked-out supercoupeperformance.com, but they don't offer the INNER bushings for the Mark VIII rear LCA's. Anyone know where I can get those?
post #5 of 14 (permalink) Old 09-17-2009, 07:33 PM
DLF
DLF's Avatar
As far as I know, I'm the only one on the planet that makes 93-98 Mark VIII LCA bushings.
http://www.sccoa.com/forums/showthread.php?t=105574
My Web Site
DLF is offline
post #6 of 14 (permalink) Old 09-26-2009, 02:45 PM
Why wouldnt the ford dealership have them?
KRUG MOTORSPORTS
57 Chevy 410ci / 66 Chevelle ss 396ci / 67 Chevy C/10 350ci / 70 Chevy C/30 8in lift 355ci / 70 Camaro Z28 406ci / 87 Mustang GT 454 ci Chevy /87 F/150 4X4 302ci /95 T-bird 281ci / 95 T-bird 281ci /06 Harley Street Bob 96ci
Deadman is offline
post #7 of 14 (permalink) Old 09-26-2009, 03:21 PM Thread Starter
Obsolete!
post #8 of 14 (permalink) Old 09-26-2009, 11:16 PM
Originally Posted by dmw_4814 View Post
Obsolete!
As is a lot of things on our cars these days...
post #9 of 14 (permalink) Old 09-28-2009, 10:03 AM
mercury267's Avatar
Why do you state these are only for off road use?
- Jesus Christ
post #10 of 14 (permalink) Old 09-28-2009, 12:05 PM
Not DOT approved, I would guess...
post #11 of 14 (permalink) Old 09-28-2009, 02:03 PM
3VIL95SC's Avatar
from what I hear these are quite a mod!
caution: pedestrians can cause major track hypnosis spurring quick side to side movements, squealing tires, drifting and outrageous smiles in skilled drivers. only cure for this is get the crazy SC diver out from behind the wheel!!!
3VIL95SC is offline
post #12 of 14 (permalink) Old 09-28-2009, 03:43 PM
DLF
DLF's Avatar
Liability....
My Web Site
DLF is offline
post #13 of 14 (permalink) Old 09-29-2009, 09:11 AM
mercury267's Avatar
I figured liability.
Let's face it, no one, including myself wants to face a lawsuit when somebody whrecks their crap into a pole at 80 MPH and their family and lawyer want to put the blame on someone. It is funny how those things work... the dead guy might not have performed a single thread of maintenance or installed the bushings properly (i.e. torque specs ignored etc), but DLF is spending the next 25 behind bars surfing TCCOA on with his back against the wall.
I was hoping that there might be more supportive comments given on the quality of these components and materials and processes used to make them.
Also, was there a price given for just the inner Mark VIII LCA bushing?
- Jesus Christ
post #14 of 14 (permalink) Old 09-29-2009, 09:55 AM
DLF
DLF's Avatar
More info in these posts:
http://www.lincolnsofdistinction.org...ad.php?t=24875
http://home.comcast.net/~dlfraleigh/Delrin/Delrin.html
If you have any more questions, send me a PM, I'll be glad to answer them.
My Web Site
DLF is offline
