Mark VIII IRS - TCCoA Forums
post #1 of 5 (permalink) Old 09-16-2009, 06:23 PM Thread Starter
Mark VIII IRS
Will a 95 Mark VIII IRS fit work on a 97 tbird? Assuming we are replacing the bags with springs. Shouldn't be an exact swap?
97_tbird is offline
post #2 of 5 (permalink) Old 09-16-2009, 07:13 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Yes, but you have to get some spring perches if you don't use the airbags.
tinman_72 is offline
post #3 of 5 (permalink) Old 09-17-2009, 06:24 AM
Yes, but be advised that ALL Mark VIII's have open differentials.
IMHO, there really isn't enough difference between the two to really justify a swap. To my knowledge the only major differences are the lower control arms are lighter on the Mark VIII and the Mark VIII's differential housing is lighter, but doesn't come with posi.
But I guess it depends on the intended application, and just my .02.
69 F100 LWB w/460 Engine
post #4 of 5 (permalink) Old 09-17-2009, 09:47 AM
tinman_72's Avatar
Interesting, I never knew that first tidbit.
If you want the advantage of lighter parts it will be much easier to just swap the control arms and the pumpkin. (After you install Trac-Lok and steeper gears, of course!)
post #5 of 5 (permalink) Old 09-17-2009, 10:16 AM
Yeah, the only gear ratios available were 3.07 open or 3.27 open....
