which way do Ford's strut rod bushings go in? - TCCoA Forums
post #1 of 14 (permalink) Old 09-20-2009, 10:06 PM Thread Starter
I'm rebuilding the front suspension, and have removed the new strut rod bushings (from Ford) that I had installed a few months ago. At the time I questioned if they were put in right and the consensus was according to the 1st pic below, the bushing between the strut rod and LCA (top one in pic) was in backward.
Now that I have them out, and can test fit with the new LCA, it seems like that is how they really are supposed to fit in.
I've taken pics of the 2 possible configurations. Which one is correct? (The last 2 pics show passenger side LCA, so the strut rod comes in from the right).
configuration #1
configuration #2
__________________
1996 Cougar XR7 Sport 4.6
J-mod, B&M tranny cooler, chip, FRPP pulleys, 02 MAF
Chad N. is offline
post #2 of 14 (permalink) Old 09-20-2009, 11:16 PM
DLF
DLF's Avatar
I believe that they are marked "inner" and "outer". At least the set I just got from Ford was.
Oops, I mis-understood the question.
Configuration #1 is the answer.
My Web Site
DLF is offline
post #3 of 14 (permalink) Old 09-21-2009, 02:49 AM
Yes, I agree - Configuration #1!
You said those are Ford bushings, right? Did you get them seperately or did they come in a kit?
post #4 of 14 (permalink) Old 09-21-2009, 09:26 AM Thread Starter
Thanks for the info!
I kind of thought I was given the wrong info in this post back in May: http://forums.tccoa.com/showthread.php?t=121771
I don't know if they came seperately or in a kit. In May I took the car to a shop to replace the steering rack, and they did the bushings at the same time. They got the parts from the dealership, but that's all I know.
__________________
Chad N. is offline
post #5 of 14 (permalink) Old 09-21-2009, 05:34 PM
DLF
DLF's Avatar
You do know that all 4 bushings aren't the same. right? There's a different part number for the inner and outer bushings. Make sure that you have them in the correct places.
My Web Site
DLF is offline
post #6 of 14 (permalink) Old 09-21-2009, 05:56 PM
The following 2 diagrams should help clear up any confusion as to how the bushings/washers/nuts should be assembled on the front suspension tension struts (they are directly from the Ford factory service info):
post #7 of 14 (permalink) Old 09-22-2009, 06:41 PM
The OEM bushings are actually marked front and rear if memory serves.
Duffy Floyd is offline
post #8 of 14 (permalink) Old 09-27-2009, 03:35 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
I did mine last week and i dont think the rear ones said anything but 2 said front .
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #9 of 14 (permalink) Old 10-06-2010, 03:33 PM
N8tiveJuggalo17's Avatar
I bought some masterpro strut rod bushings and they dont fit to well it seems, my old ones were literally falling off in several pieces so i cant use them as a guide... i was wondering how they went on... they look like this except for the color...
N8tiveJuggalo17 is offline
post #10 of 14 (permalink) Old 04-24-2011, 04:49 PM
crash00527's Avatar
Send a message via AIM to crash00527
DONT buy ANYTHING but OEM for THESE parts! Must everyone learn the hard way? lol
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #11 of 14 (permalink) Old 04-24-2011, 05:50 PM
So 4 strut bushings per side.
How much do they cost from the dealer?
JasonWW is offline
post #12 of 14 (permalink) Old 04-24-2011, 05:55 PM
I paid $42.sumpin' for the full set of front bushings at my local Ford dealer.
The rears are about $50 for both sides.
HOWEVER - it seems the rear can be 3rd party as long as they're good ones. I've got Moog on mine, and that's not where my problem is.
RalphP is offline
post #13 of 14 (permalink) Old 04-24-2011, 06:22 PM
I wonder if they be changed without getting the alignment done afterwards? Try to keep the costs down.
Maybe paint the threads so I can adjust it to the same spot?
JasonWW is offline
post #14 of 14 (permalink) Old 04-24-2011, 06:31 PM
I wouldn't trust that.
I understand the "Be Cheap" - but for that adjustment, you'll find that if it's off, the car may pull one way or another and be hard to steer / hard to return to straight ahead. Or any combination of the above.
HOWEVER - you may be able to talk them into a simple 2-wheel alignment (which is cheaper most places.)
RalphP is offline
