what the heck? harsh ride after replacing cats! - TCCoA Forums
post #1 of 18 (permalink) Old 09-25-2009, 03:27 PM Thread Starter
ortbird's Avatar
Exclamation what the heck? harsh ride after replacing cats!
yeah i know - doesn't make sense>
so i did the long overdue replacement of the cats (one cat has been giving me the "efficiency below thershold" code for about 2 yrs now, and i went ahead and got the whole direct fit Y pipe thing replaced with new cats and new O2 sensors -front O2's, that is).
This is the 2nd "repair" of any kind i have done on this car - 1st one was getting the aluminum crossover intake as a precaution.
at the same time i told the guy (former Ford master tech) to check under the car and see if ANY suspension parts need replacing/repairing (car has 127 k miles); he said he checked all that, and everything checked out fine - my car is gently driven. He did mention that they checked the alignment and tires... but didn;t mention adjusting anything - certainly was not charged for anything...
So car feels great now, EXCEPT HARSH RIDE !!!! I felt it AS SOON AS I drove off after getting the car back.
I KNOW - i am not psycho - idk why the hell this should happen, but it feels like it has no shocks (they're there - i checked LOL) - jarring ride over even the smallest stuff, like white arrows on the road, i mean HARSH - no funny noises or anything, but man you FEEL it. it's BOUNCY!
This car has the sports suspension, but i can never remember it being this "solid" and harsh...
They did NOT do anything to the suspension... could they have needed ANY fooling with the suspension to replace the Y pipe/cats? probably not, huh?
what could have happened? did they perhaps put some air in the tires and overinflated them? That's the only thing i can think of - didn't get a chance to see how much air in them yet.... (I normally run 33 PSI) They do the full check up when a car is brought to them for the 1st time... and I do remember him saying we checked out everything under car including the TIRES ....
I am baffled, and i don't wanna sound like an idiot and call them and ask "hey did you put air in the tires?"
could my shocks finally have given up RIGHT WHEN i got the car back ??? heck of a coincidence I'd think...
ortbird is offline
post #2 of 18 (permalink) Old 09-25-2009, 03:51 PM
unless you have a broken shock, they usually just don't break.
they would wear out over time.
now, you could possibly have a broken spring.
post #3 of 18 (permalink) Old 09-25-2009, 04:03 PM Thread Starter
ortbird's Avatar
Thanks!
Now a broken spring should be pretty visible, right? Gonna check right now.
ortbird is offline
post #4 of 18 (permalink) Old 09-25-2009, 04:23 PM
You wouldn't necessarily be able to see the spring broken, but it would cause one corner of the car to sit lower than the rest.
post #5 of 18 (permalink) Old 09-25-2009, 04:29 PM Thread Starter
ortbird's Avatar
can't see anything abnormal - car sits straight and even.
something tells me it's the tire pressure...
I do have the 235/60/16 tires, so i guess over inflation can be more dramatic than with stock 225/60/16 size (?) ....
gotta go and check the tire pressure as soon as rain stops...
thanks guys...will update.
ortbird is offline
post #6 of 18 (permalink) Old 09-25-2009, 04:41 PM
maybe they retorqued all the suspension bolts and now all the bushings nice and tight again????
Justin McC
Stinkfist04 is offline
post #7 of 18 (permalink) Old 09-25-2009, 04:55 PM Thread Starter
ortbird's Avatar
well, I bit the bullet and called the place: he says they checked the suspension for looseness in any joints/parts but didn't find anything amiss - so they didn't really tighten anything OR add air to tires as far as he knows !!!
WHAT in the world !! I mean I KNOW my car so well, and it was not BOUNCY like this!
Now, the other possibility is that my front shocks kicked the bucket JUST when I drove home and they need replacing now.... but how bizarre is THAT? .wouldn't they have seen THAT when they were checking under car?
is this all in my head?
ortbird is offline
post #8 of 18 (permalink) Old 09-25-2009, 04:59 PM
Faster than Porkchop
cjchevez's Avatar
I run into something like your issue but not the same , I got my exhaust put in and when I drove off my drive shaft was rubbing . I know they didn't mess with the shaft but I am rubbing now .
Fun stuff ha ?
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #9 of 18 (permalink) Old 09-25-2009, 05:00 PM
bob9646's Avatar
Before I fell in love with mn12s I had a friend with an 89 sc that had some kind of ride stiffening button, "normal" and "sport"
Do sport models have this feature?
Shipping out to basic training for the army on april 12th!
Bird is on serious down time
bob9646 is offline
post #10 of 18 (permalink) Old 09-25-2009, 05:00 PM Thread Starter
ortbird's Avatar
No. They don't. They just have stiffer springs/shocks, but not THIS stiff....
I wonder if one of the guys working there, unawares to the "main" guy did tighten some stuff or add air to tires...??? I guess I'll have to check tire pressure anyways.
ortbird is offline
post #11 of 18 (permalink) Old 09-25-2009, 05:27 PM
not sure how clean you keep your under carriage but look at your shock bolts, endlink bolts, all of them, see if they look cleaner than surrounding parts like buildup of road gunk has been recently knocked off of them from a socket or wrench. check the bushings they shouldn't be smashed wider than the washers.. i don't think i've heard of a shock just up and kick the bucket in less a major hit was taken to it. any sqeeks, clunks, rattles, any noises?
Justin McC
post #12 of 18 (permalink) Old 09-25-2009, 05:32 PM Thread Starter
ortbird's Avatar
No noises of any kind - not even when i go over some rough spot and notice the harshness/bouncy-ness...
i am not sure it's a BAD difference that i am noticing - it sure is very DIFFERENT - and a bit too solid/stiff or something. and i feel even the slightest uneven spot as if it was a speed bump - well that's exaggerated, but u know...
will check what you suggested as soon as damn storm stops. Thanks.
ortbird is offline
post #13 of 18 (permalink) Old 09-25-2009, 05:57 PM
try quickly pushing down on the car on each corner with as much body weight as you can and quickly let off see if there's a corner that's noticeably stiffer. unless your like 100lbs lol you should be able to push the car down a little..i dunno.
Justin McC
post #14 of 18 (permalink) Old 09-25-2009, 07:00 PM Thread Starter
ortbird's Avatar
i weigh 122 lbs
ortbird is offline
post #15 of 18 (permalink) Old 09-25-2009, 09:06 PM
bob9646's Avatar
Originally Posted by ortbird View Post
i weigh 122 lbs
Yay I'm not the smalest guy here lol I'm a buck thirty.. You should still be able to move it, it won't bounce off the bump stops but it'll move. And hey, you don't have to worry about denting your hood!
bob9646 is offline
post #16 of 18 (permalink) Old 09-26-2009, 12:04 PM Thread Starter
ortbird's Avatar
hey guys, someone that i know had this to say ... Is this possible at all?
If it was put on a lift where the wheels hang suspended, perhaps it did "finish off" one or more of the shock/struts by expanding them fully for a time and then compressing them when the car was lowered.
in the worst case, I had already secured a pair of low-mile front sport shocks from someone here about an year ago... i guess i can have them put those on, huh? maybe it's time for shocks anyway ????
ortbird is offline
post #17 of 18 (permalink) Old 09-26-2009, 10:23 PM
carcrz's Avatar
you got to let us know what was the prob.
carcrz is offline
post #18 of 18 (permalink) Old 09-27-2009, 12:47 AM Thread Starter
ortbird's Avatar
I sure will. thanks.
ortbird is offline
