Help, how do i mount my mark VIII LCA - TCCoA Forums
post #1 of 11 (permalink) Old 09-26-2009, 02:59 PM Thread Starter
I just picked up a set of 95 Mark VII rear lower control arms from a board member for my 95 bird, vary happy with the purchase. But how do you mount them??? The mounts where the spindle attach are different then the bird. The bird has like a u bracket on each end to attach to the spindle and the mark doesnt, just 1 post at each end. thanks for the help. I also picked up a 93 pumpkin, i hope that is straight forward swap??? Thanks
KRUG MOTORSPORTS
57 Chevy 410ci / 66 Chevelle ss 396ci / 67 Chevy C/10 350ci / 70 Chevy C/30 8in lift 355ci / 70 Camaro Z28 406ci / 87 Mustang GT 454 ci Chevy /87 F/150 4X4 302ci /95 T-bird 281ci / 95 T-bird 281ci /06 Harley Street Bob 96ci
Deadman is offline
post #2 of 11 (permalink) Old 09-26-2009, 03:20 PM
dDUBb's Avatar
You need to remove the half shaft from the knuckle ( spindle ) to get those bolts in if you are re-using the original bolts that came with the Mark LCA .. not sure about re-using the factory bolts.
dDUBb is offline
post #3 of 11 (permalink) Old 09-26-2009, 04:24 PM Thread Starter
No thats not the problem, the mounting points at the arm are different. They dont line up with the knuckle.
KRUG MOTORSPORTS
Deadman is offline
post #4 of 11 (permalink) Old 09-26-2009, 06:26 PM
DLF
DLF's Avatar
First, you probably need the stock Mark VIII Torx LCA to Knuckle mounting bolts, I don't believe that the MN-12 bolts will work.
The Knuckle mounts to the forward side of the tabs on the Mark VIII LCA.
Here are three pics showing the Mark VIII LCA's installed (with my Delrin Bushing Kit) in my '95 SC (pass. side), which may help you visualize things.
My Web Site
DLF is offline
post #5 of 11 (permalink) Old 09-27-2009, 12:10 PM Thread Starter
Got it thats the problem i was trying to visualize them since they look different i was thinking the wouldnt fit. thanks alot
KRUG MOTORSPORTS
Deadman is offline
post #6 of 11 (permalink) Old 11-20-2009, 12:26 PM
392Bird's Avatar
Does anyone have the specs on the washers that go between the spindle and lower control arms? I want to make sure they are not too tight, or loose.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #7 of 11 (permalink) Old 11-20-2009, 02:25 PM
Are you asking about torque specs?Any thick flat zinc coated or stainless steel fender washer should work.
Use lithium grease on the bushings.
All stock 1990 Merc Blue Max Cougar 3.8L with Automatic
ben2go is offline
post #8 of 11 (permalink) Old 11-20-2009, 04:27 PM
DLF
DLF's Avatar
The washer goes between the LCA and the spacer in the center of the bushing. It has no effect on how tight the spindles are. It's there just to prevent the bushing spacer from digging into the aluminum LCA.
A 16mm or 1/2" fender washer will do.
My Web Site
DLF is offline
post #9 of 11 (permalink) Old 11-21-2009, 07:53 AM
392Bird's Avatar
Are the washers to fit between the end of the sleeve in the bushing on the spindle and the control arm, or over the sleeve in the bushing?
392Bird is offline
post #10 of 11 (permalink) Old 11-21-2009, 07:55 AM
DLF
DLF's Avatar
End of the sleeve....
My Web Site
DLF is offline
post #11 of 11 (permalink) Old 11-21-2009, 08:16 AM
392Bird's Avatar
I figured it was to go there to prevent the sleeve from digging into the aluminum control arm, but wanted to make sure. Thanks.
392Bird is offline
