how much torque do need on hub retainer bolt? - TCCoA Forums
post #1 of 11 (permalink) Old 09-27-2009, 06:35 PM Thread Starter
how much torque do need on hub retainer bolt? for front hubs trying to get my braks back together. Thanks
97_tbird is offline
post #2 of 11 (permalink) Old 09-27-2009, 07:44 PM
Are you talking about the large 36mm nut at the center of the wheel hubs? If so, 188-254 ft-lbs.
post #3 of 11 (permalink) Old 09-27-2009, 08:52 PM Thread Starter
thats the one. Seems pretty tight on the bearing though.
97_tbird is offline
post #4 of 11 (permalink) Old 09-28-2009, 06:55 AM
seeming tight and actually being tight to the right spec are two different things.
I don't know about you but I wouldn't want that coming loose while I was driving because I THOUGHT it semed tight enough.
I tightened mine to 250ft-lbs.
BigJohnny is offline
post #5 of 11 (permalink) Old 09-28-2009, 07:56 AM
DLF
DLF's Avatar
It's not bearing preload, its retention to the spindle.
My Web Site
DLF is offline
post #6 of 11 (permalink) Old 09-28-2009, 08:11 AM Thread Starter
250 ft-lbs is that the factory spec? When I pulled the dust cap off I expected a carter pin of some sort but there was only a bolt with a racer washer attached to it. That alone seemed scary to me.
97_tbird is offline
post #7 of 11 (permalink) Old 09-28-2009, 08:17 AM
DLF
DLF's Avatar
Brandon gave you the answer above.
From the Ford shop manual:
Install new front axle wheel hub retainer and tighten to 255-345 Nm (188-254 lb-ft).
My Web Site
DLF is offline
post #8 of 11 (permalink) Old 09-28-2009, 08:19 AM
What's the point in asking a question if you're not going to believe the answer?
post #9 of 11 (permalink) Old 09-28-2009, 08:25 AM
cause its the American/internet way.
seems some want it spelled out 20 times with 14 links......
post #10 of 11 (permalink) Old 09-28-2009, 11:47 AM Thread Starter
Thanks for all of your help.
97_tbird is offline
post #11 of 11 (permalink) Old 09-28-2009, 12:01 PM
An important note:
Install new front axle wheel hub retainer and tighten to 188-254 lb-ft.
The retainer is not reusable.
69 F100 LWB w/460 Engine
