Hub swaps? - TCCoA Forums
post #1 of 7 (permalink) Old 10-15-2009, 02:29 PM Thread Starter
Miakehl's Avatar
Hub swaps?
What possible hub swaps are feasible with these cars?
The reason I ask is because I found a set of rims online for like $89 a piece that would look killer but they're for a 2005 Mustang...
What are the bolt spacing that's stock and what all can it be swapped out to? I have no problem with the process since the entire suspension is getting an overhaul rather quickly.
1994 Ford Thunderbird LX - 120xxx Mi
3.8L of leaking fury
1995 Ford Thunderbird LX - 108xxx Mi
Stock 4.6
Miakehl is offline
post #2 of 7 (permalink) Old 10-15-2009, 03:49 PM
The Great Obucina's Avatar
http://www.tccoa.com/articles/suspension/index.html
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 7 (permalink) Old 10-15-2009, 07:22 PM
tbirdtess's Avatar
Sn95
Hello
You can use SN95 front & rear hubs.
You can get them from "Fast Ed"
Use 99 Mustang front rotors & hubs
Use same rear hubs & redrill your rear rotors or drums
You need 94 up front spindles & calipers.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #4 of 7 (permalink) Old 10-15-2009, 08:16 PM Thread Starter
Miakehl's Avatar
Originally Posted by tbirdtess View Post
Hello
Paul
Could it be possible to just do a big brake upgrade for that year Mustang? I want to upgrade the brakes while it's apart to compensate for the 20s and sound system.
Stock 4.6
Miakehl is offline
post #5 of 7 (permalink) Old 10-15-2009, 08:23 PM
tbirdtess's Avatar
still
Hello
you would still need the hubs. Don't know if the will fit. Don't think so.
351W 2bbl.
C-4 Auto
3.90 open rear
post #6 of 7 (permalink) Old 10-15-2009, 08:49 PM
did you bother to read the articles i linked you to? your hub and brake questions would both be answered.
post #7 of 7 (permalink) Old 10-31-2009, 07:03 AM
Banned
You have a choice! YOu can send your rear hubs and rotors to Stu at:http://irsmachining.com/. For the price of the cobra rear hubs you get the MN12 rear hubs and rotors drilled to SN95. Put them back on you car and your done with the rear.
Then for the front buy a set of front hubs from an SN95 mustang and the front rotors and put them on your MN12. Bolt on swap. You are done! YOu save a bunch of money and trouble. The easiest and least expensive way to go to a wheel change to Mustang SN95. YOu can later upgrade you front calipers using Mustang PBR's or upgrade to the cobra rotors and calipers. However this set up is great and works well. You will be happy
lexx007 is offline
