While I was replacing a wheel bearing... - TCCoA Forums
post #1 of 12 (permalink) Old 11-07-2009, 06:19 PM Thread Starter
I discovered my right rear knuckle is cracked at the bearing area
I found a guy on ebay with a brand new knuckle with bearing and bushings for 125.00 plus shipping, is this reasonable? Sounds like it but I wanted other opinions first before I commit.
Chris
N2HTWLZ is offline
post #2 of 12 (permalink) Old 11-07-2009, 10:40 PM
CrystalPistol's Avatar
How on earth did that happen I wonder?
CrystalPistol is offline
post #3 of 12 (permalink) Old 11-07-2009, 11:09 PM Thread Starter
Not sure, I have only owned the Cougar for about 3 months.
N2HTWLZ is offline
post #4 of 12 (permalink) Old 11-08-2009, 08:18 PM
Sounds like the car has been jumped or ran onto a curb at high speed.
All stock 1990 Merc Blue Max Cougar 3.8L with Automatic
ben2go is offline
post #5 of 12 (permalink) Old 11-15-2009, 02:50 PM
You can break them pretty easily with a press, putting the bearings in wrong...
I have a large, aluminum desk ornament that's cracked, with part of a bearing embedded in it.
Part of my support slipped with about 10,000psi on it.
I'd find a new one; the "parts wanted" section helped me, AFAICR.
A rear knuckle from any matching brake type car will work; bird, cougar, or mark 8 (if you have disks).
Grog6 is online now
post #6 of 12 (permalink) Old 11-15-2009, 07:05 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
does the car have rear disc or drums ? I might have what you need .
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #7 of 12 (permalink) Old 11-16-2009, 12:20 PM
It doesn't matter, the knuckle is the same for both.
post #8 of 12 (permalink) Old 11-16-2009, 01:29 PM
Boost Happy
Jurgen's Avatar
i know that but i could send him one with hub backing plate or disc and all that so he wouldt have to transfer all the stuff .
2002 Corvette Z06
Jurgen is offline
post #9 of 12 (permalink) Old 11-16-2009, 02:11 PM
dDUBb's Avatar
Not exactly. The knuckles from a car with rear Drums will not have the bosses drilled out for the bolt holes on the caliper mounting bracket. You would need to drill and tap them out to put rear discs on a drum knuckle.
dDUBb is offline
post #10 of 12 (permalink) Old 11-16-2009, 03:07 PM
You would need to drill them, not tap them. The threads are in the bracket for the caliper, so it is just a matter of drilling 2 holes, which is easy enough.
post #11 of 12 (permalink) Old 11-16-2009, 07:48 PM
I didn't realize that; can't see the bosses behind the backing plate, lol.
Good to know; I know where more parts are now. I need one more...
I have a template to drill the holes by, too.
Grog6 is online now
post #12 of 12 (permalink) Old 11-17-2009, 06:57 AM
This is good info.My local yards want $80 to $120 per disc brake spindle.So I can save $160 to $240 and drill my own.
Where'd I put my drill press?
ben2go is offline
