lowering car need help... - TCCoA Forums
post #1 of 15 (permalink) Old 11-25-2009, 02:50 PM Thread Starter
danalba's Avatar
im in the process of lowering my car. however i cant get the top nut of the rear shock off. it just rotates the whole bolt its threaded too. how can i get this thing off
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 15 (permalink) Old 11-25-2009, 04:23 PM
dDUBb's Avatar
You should have removed the nuts for the shocks while the vehicle was still on the ground .. put a load under it with a jack or use a wrench to hold the middle post while you unscrew the nut .. once it gets loose, it should come off easily by hand.
dDUBb is offline
post #3 of 15 (permalink) Old 11-25-2009, 04:27 PM
David_viny's Avatar
Does it have a hex shape at the top of the threads? I cant remember really, but I thought I was able to put a wrench on that hex part of the shaft to hold it from turning, and also one on the bolt to loosen it.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #4 of 15 (permalink) Old 11-25-2009, 05:46 PM
carcrz's Avatar
cut it off and replace the shock its probably old and needs replacing anyways
1989 THUNDERBIRD
3.8 LITER
BLOWN HEAD GASKETS
H\G fixed
carcrz is offline
post #5 of 15 (permalink) Old 11-25-2009, 06:54 PM Thread Starter
danalba's Avatar
haha well i am replacing them.... i did end up getting it off and everything is put back together not. but the last thing i have to do is get the rear shocks top nut back on. its a lock bolt with plastic at the end, i cant thread it through enough to get ahold of the shaft. thanks for the help, sctbird i think has it in the bag though, only way ill be able to tighten the thing is under load.... i hope, so the shaft wont spin
PI intake/PI cams
355 trac lok
danalba is offline
post #6 of 15 (permalink) Old 11-25-2009, 07:13 PM Thread Starter
danalba's Avatar
still wont tighten under load.... center shaft just spins... this one is not heck (bilstein) its just threads, i cant even get to the threads though, cant screw bolt on far enough....
PI intake/PI cams
355 trac lok
danalba is offline
post #7 of 15 (permalink) Old 11-25-2009, 10:11 PM
Wrap a thick piece of leather around the threads below the bolt, and clamp vicegrips over it.
It will grip well enough to tighten the bolt down to where you can get a wrench on the tip.
Don't overtighten the vicegrips! If they cut thru the leather, it doesn't work very well at protecting the threads, lol.
Seems like the top hex is 5/16 or 8mm.
post #8 of 15 (permalink) Old 11-26-2009, 03:37 PM
dDUBb's Avatar
Dont tighten the shock topnuts until after the car is back on the ground and all of the weight of the car is pushing the springs down or you will be fighting them.
dDUBb is offline
post #9 of 15 (permalink) Old 11-26-2009, 04:47 PM Thread Starter
danalba's Avatar
thats what i did. i tightened them the best i can. they only require 27 pounds torque so i did my best. even under the weight of the car the center shaft spins..
PI intake/PI cams
355 trac lok
danalba is offline
post #10 of 15 (permalink) Old 11-26-2009, 04:52 PM
dDUBb's Avatar
It's spinning because of those stupid nylon locking nuts. Those are a lot of fun when they are on things like Endlinks and Lower control arms ..
Your stock nut wouldnt fit on the new shock ?
dDUBb is offline
post #11 of 15 (permalink) Old 11-26-2009, 06:26 PM Thread Starter
danalba's Avatar
yes your right the nylon idea=not good. but i didnt think of my old nut... i shall try this... thanks for the obvious advice haha
PI intake/PI cams
355 trac lok
danalba is offline
post #12 of 15 (permalink) Old 12-05-2009, 07:36 PM
Black_Cat's Avatar
Deep well impact socket and an Ingersoll Rand 1/2" impact gun....worked for me make sure to use spring compressors !
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #13 of 15 (permalink) Old 12-05-2009, 10:09 PM Thread Starter
danalba's Avatar
haha well i think your on your own path there. not sure what your talking about with the whole spring compressor..and im not a power tool guru (didnt think they had torque setting) but they are torque specific one. two not sure i could even get an impact gun in the space. three that still doesnt solve my problem with the shaft that the nut threads onto spinning... but i appreciate the effort. i ended up using my old nuts.. ha.. and getting them on there as tight as i could..
PI intake/PI cams
355 trac lok
danalba is offline
post #14 of 15 (permalink) Old 12-05-2009, 11:44 PM
Black_Cat's Avatar
Oh your doing the rear, it's easy man...see I did shocks AND springs so I needed the compressors...if your just doing the shock, then put the new one in and use a closed spanner wrench on the large shock nut and a socket on the top of the actual shock to hold it in place. I basically did my KONI's with a 3/4" spanner and a socket wrench on the top holding the shock. The koni's called for around 60 ft lbs of torque, all in all just tighten the nut down until you can almost not turn the wrench anymore and you should be good. Here is a picture of how I tightened mine.
Just remember your camber will be off when it gets lowered, and if you adjust it like I did myself, your toe will be screwed up and must also be adjusted. Get it professionally aligned in the end, but temporarily you can do it yourself using a tape measure.
post #15 of 15 (permalink) Old 12-05-2009, 11:52 PM
I've never needed a compressor with mine.
