handling - suspension/sway bar upgrades? - TCCoA Forums
post #1 of 11 (permalink) Old 11-26-2009, 10:49 PM Thread Starter
so, i'm building my 95 tbird up, and would really love to take advantage of the irs (combined with a turbo 4.6 and possibly t45 swap), and make a really sweet handling mn12 (not that the handling is bad on a stock car)
i want to keep the ride height where it is, or really close (not slamming) and i want to lower the amount of body roll
has anyone upgraded their suspension similar to what i want?
any info would be great thanks!
1995 Thunderbird Project ThunderSnake
1987 Mercury Cougar 2.3L Turbo 5 Speed DD
josh_marotte is offline
post #2 of 11 (permalink) Old 11-27-2009, 09:50 AM
R8D-XXX's Avatar
For our cars, you can buy thicker sway bars, better shocks, struts, and buy all polyeurethane bushings for a lot of suspension components. As far as springs go, I would recommend a good set of Eibachs or Vogtland springs which will give your car about a 1.5" drop and handle better. But if you want to keep close to the stock ride height, I guess your next best choice would be to go with a set of T-Bird SC springs.
Also, check out the suspension Tech articles.
http://www.tccoa.com/articles/suspension/index.html#
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #3 of 11 (permalink) Old 11-27-2009, 01:06 PM
SC or sport springs (they are the same thing) will help a lot while keeping stock ride height. Combine that with stiffere shocks and sway bars, and the car will handle very well.
post #4 of 11 (permalink) Old 11-27-2009, 01:17 PM
CrystalPistol's Avatar
And when you put those fat bars, stiff shocks, & stout springs on it and then beat it over unlevel ground, you'll soon consider some bracing.
CrystalPistol is offline
post #5 of 11 (permalink) Old 11-27-2009, 04:12 PM
Watch for cracks around the tunnel in the rear.
All stock 1990 Merc Blue Max Cougar 3.8L with Automatic
ben2go is offline
post #6 of 11 (permalink) Old 11-28-2009, 05:36 PM
consider delrin bushings for the IRS for the best handling possible(i dont even have them and he sold me on it). One guy on sccoa makes em, i think he stop here too.
post #7 of 11 (permalink) Old 11-28-2009, 07:06 PM
Are those better in the front also?I hear bad things about poly bushings in the front.I was planning to run poly all around until I heard some cars split them.Does having a metal sleeve around the polys help?The last vehicles(not MN12) I did polys on had steel sleeves on the bushings.
ben2go is offline
post #8 of 11 (permalink) Old 11-28-2009, 07:08 PM
Poly is bad with the strut rods, everything else you'll be ok.
post #9 of 11 (permalink) Old 11-28-2009, 07:32 PM
Thanks for clearing that up.
ben2go is offline
post #10 of 11 (permalink) Old 11-28-2009, 10:21 PM
Yeah, them cracks behind the motor over the trans tunnel in the firewall for one thing.
post #11 of 11 (permalink) Old 11-29-2009, 05:40 PM Thread Starter
alright awesome, thanks for the ideas guys!
