My shorter Sway bar end links won't go in. - TCCoA Forums
post #1 of 16 (permalink) Old 12-05-2009, 07:50 PM Thread Starter
Black_Cat's Avatar
Ok, so i've read the tech articles, and tried my hardest to solve this issue myself, but it's not working out. I've recently lowered my cougar with KONI shocks and 1.6" Vogtland lowering springs...but when I try to install the new shorter rear sway bar end links, I can't get them in enough to get the nut on the end link even with the entire weight on the car and 3 people sitting in my trunk haha. Can anyone help me here, it's starting to annoy me.
Parts:
- Stock Rear Sway Bar
- SCP Shorter Rear Sway Bar End Links
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #2 of 16 (permalink) Old 12-05-2009, 09:03 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Are you trying to put them on one at a time? You should take both of them off at the same time, and install both of the new shorter ones at the same time.
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #3 of 16 (permalink) Old 12-05-2009, 10:44 PM Thread Starter
Black_Cat's Avatar
Yep I did both, because with both off the sway bar moves up and down freely, but even with both in at one time, I can't get the nut on the top of the sway bar links.
post #4 of 16 (permalink) Old 12-05-2009, 10:57 PM
I don't know what to tell you other than to check and see if it is binding or hitting anything or binding in the rubber bushings.
-Rob
post #5 of 16 (permalink) Old 12-05-2009, 11:19 PM Thread Starter
Black_Cat's Avatar
I think the end bolts are TOO short....just my .02
post #6 of 16 (permalink) Old 12-05-2009, 11:24 PM
decipha's Avatar
had a similar problem on a friend of mine 94 gm 1500 truck 2 weekends ago
his sway bar end link bushings were SHOT. So we went to autozone and got the universal sway bar bushings kit in red polyurethane. As you I tried everything on earth to get those bushings in there and it just wouldn't work. Upon closer examination I discovered the problem.
The poly bushings were thicker than the oem bushings so I had to trim the center sleeve to bring the bushings back down to the proper load height.
He then had to stand on the opposite side of the truck while I bolted the new bushings in
all is well truck drives excellent and doesn't handle like a boat anymore
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #7 of 16 (permalink) Old 12-06-2009, 12:07 AM Thread Starter
Black_Cat's Avatar
Yea I bought the other links from advance auto when i wouldn't pass inspection a few months ago because of my "lollipop" sway bar joints. So I bolted in the advance ones and lowered the car the next week. Tried super hard to get the shorter ones in there....I really want to use the polyethylene ones over the red ones...but I might just trim the black ones down till they fit.
post #8 of 16 (permalink) Old 12-18-2009, 07:07 AM
Beerdog80's Avatar
I did this to my bird a few weeks ago...same part. I just had another guy twist down on the sway bar, enough to get the threads in the mounting bracket and that was it.
Beerdog80 is offline
post #9 of 16 (permalink) Old 12-18-2009, 07:15 AM
Did you get the end links from Addco or another source?
The one's that came with my bar from Addco worked fine.
post #10 of 16 (permalink) Old 12-18-2009, 08:53 AM
Same as well
post #11 of 16 (permalink) Old 12-18-2009, 10:56 AM
tbirdtess's Avatar
Off goround?
Hello
OK
Both wheels are off the ground. correct?
Bar moves freely. correct?
Where are your jack stands?
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #12 of 16 (permalink) Old 12-18-2009, 11:45 AM
SuperNewbie
supergordo's Avatar
how long were the endlinks you bought?
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #13 of 16 (permalink) Old 12-18-2009, 01:48 PM
I had to lower mine all the way to the ground with the wheels on to get my links to fit. With jackstands on the LCA's I can't get the suspension to compress enough.
post #14 of 16 (permalink) Old 12-22-2009, 06:14 PM
tjet94's Avatar
If im understanding right I had the same problem with these links as well...i didn't lower the suspension or anything however I believe I took the strut assembly out and then put the links in and reinstalled my strut assembly. You might want to use a jack once the strut is off
Mike
tjet94 is offline
post #15 of 16 (permalink) Old 01-01-2010, 04:22 PM Thread Starter
Black_Cat's Avatar
Car was completely ON the ground with 3 people sitting in my trunk...still couldn't get them in. Got them from Bill at SCP
post #16 of 16 (permalink) Old 02-26-2010, 07:24 PM
crash00527's Avatar
Send a message via AIM to crash00527
+2
stick with OEM bushings and take both end links at the same time. make sure rear tires are flat on lift rack not swaying free.
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
