theory? - TCCoA Forums
post #1 of 4 (permalink) Old 12-07-2009, 08:42 PM Thread Starter
tbirdtess's Avatar
theory?
Hello
If I lengthen the rear upper control arm & move the mount more to the center of the car. Will I have less camber loss in a turn?
There is room to move the upper mount.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 4 (permalink) Old 12-08-2009, 01:23 AM
Boni's Avatar
AFAIK if you make longer upper arm, closer to paralel arms setup, the camber will be less but base (distance between tracks/wheels) change more on turn, and traction of outside wheel will be worse; and this is reason the paralels are not used from '60s or so. And you add some weight on arm, I guess, it always worsen traction and comfort a bit.
Other hand, short/long arms, as standard MN12, is widely recognised as best compromise for base/camber stability. So - its no reason to change this point, I think.
Dodge Shadow '88 2.2 auto
Scorpio Ghia RS '91 2.9 auto
Merkur Scorpio '89 2.9 manual
Explorer '93 40 auto Vitara '95 1.6 auto
Thunderbird SC '89 5.0HO auto
Fiero '85 2.5 auto
Boni is offline
post #3 of 4 (permalink) Old 12-08-2009, 09:40 AM Thread Starter
tbirdtess's Avatar
Rear
Hello
I am talking about the rear suspension.
351W 2bbl.
C-4 Auto
3.90 open rear
post #4 of 4 (permalink) Old 01-03-2010, 11:28 AM
I believe Boni was refering to both front and rear.
To answer your question, if you make the upper arm longer you will get less negative camber under compression (like the outside wheel under hard cornering) and less positive camber on extension (the inside wheel under hard cornering).
Hope that helps
JasonWW is offline
