Questions About Camber - TCCoA Forums
post #1 of 7 (permalink) Old 01-03-2010, 01:28 PM Thread Starter
cougar_fan's Avatar
I am getting ready to mount my newly bought tires, and have noticed a significant tread-ware descrepency between the front drivers side and the front passenger side. The tread on the drivers side is nice and evenly worn throughout the tread surface. However, the passenger side is smooth along the outer most edge, and practically brand new on the inner tread. This leads me to beleive that there is a camber issue (aka: less camber-a degree less than 90*) Would anyone reccomend tackling the issue at home, or would you take it to a shop? If so, what is the desired degree of camber for our cars? Thanks
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #2 of 7 (permalink) Old 01-03-2010, 01:48 PM
dDUBb's Avatar
Take it to the shop .. it is probably more than a little Camber causing tire wear - Toe and Caster need to be in spec as well.
dDUBb is offline
post #3 of 7 (permalink) Old 01-03-2010, 04:13 PM
BUCK's Avatar
Exclamation
Best to check your UCA's prior to installing brand new Tires.
BUCK is offline
post #4 of 7 (permalink) Old 01-03-2010, 04:31 PM
I have had the misfortune of knowing one of the best alignment men ever, from back in the early 70's (he's retired now, alas).
After seeing him work, and knowing how most people do things - if you can find a good alignment shop, PAY THEM.
Follow Pournelle's Law.
"If you don't know what you're doing, find someone who does, and pay them what they're worth."
After all, bad alignment can do more than cost you tires and gas.
RalphP is offline
post #5 of 7 (permalink) Old 01-03-2010, 05:53 PM Thread Starter
cougar_fan's Avatar
Buck, why check the UCAs? More pointedly, what am I looking for? Also, like you said RalphP, it is better safe than sorry. I'll take it to our trustred shop here in town. They regularly adjust dirt and asphalt cars so I trust them. Upon further inspection, the outside tread of the tire (aprox. 2.5" from the outer tread in) is absolutely smooth. Does anyone know the range of what our mn12 camber should be so I can request this at the shop, or will they know this off hand? Sorry for all the questions, but I am relatively new to this aspect.
post #6 of 7 (permalink) Old 01-03-2010, 07:31 PM
Check all the suspension bushings, seals, covers, etc.
If anything looks loose, cracked or worn, replace it before you spend money on an alignment.
I started with these settings, and went from there. Giving the guy feedback is also good; most Good suspension guys will let you try it out and see if you like it.
http://www.tccoa.com/articles/suspen...ent/index.html
There's a lot of good info in the articles.
A good suspension guy is hard to find; I don't know what I'll do when Walter retires...
post #7 of 7 (permalink) Old 01-03-2010, 08:42 PM Thread Starter
cougar_fan's Avatar
Thanks Grog6. I appreciate that. I've gotta get this done by April. There is no way I am taking it down the gap like this! Nice find on the article by the way. I don't know how I missed that.
