Rear Control Arm Bushings? - TCCoA Forums
post #1 of 8 (permalink) Old 01-08-2010, 01:15 PM Thread Starter
So I removed the rear upper and lower control arms on my 96' Tbird. I took all 4 arms to a mechanic to press in replacement bushings, but he was unable to tell me how much he would charge - besides a $300 ballpark quote not on paper. Right away, he stated that the upper arm bushings were fine and did not need replacement. He did not comment on the lower arm bushings.
The bushings appear to be in OK condition with just a little bit of cracking rubber evident on one bushing per side - both the rearward bushings. The bushings have very limited deflection apparent. I was going to have them replaced because I have it all apart, but if I can get by a while more I might hold off.
What would you recommend that I do? Have them replaced, or return the bushings and save $150+ (bushings 50, labor to press in and out is the ???) I am also hoping to one day get the delrin bushings so might be best to wait I suppose.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #2 of 8 (permalink) Old 01-08-2010, 04:36 PM
DLF
DLF's Avatar
If you're going to get one of my Delrin Kits at some point, why waste the money now if you don't have to?
My Web Site
DLF is offline
post #3 of 8 (permalink) Old 01-08-2010, 11:09 PM
Replacing mine made a huge difference, it just depends on how bad yours are.
I believe some of the bushings are liquid filled; I know the toe adjusters are. Mine were empty when removed.
They're 14 years old, you have them off the car; you can buy a decent press for ~$200.
I wouldn't pay more than that to have them replaced. You'd be amazed what you can break with a press...
post #4 of 8 (permalink) Old 01-17-2010, 01:06 PM
tbirdtess's Avatar
Case removal?
Hello
What was the best way to remove the metal cases?
on the lower rear control arms.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #5 of 8 (permalink) Old 01-17-2010, 01:33 PM
DLF
DLF's Avatar
Originally Posted by tbirdtess View Post
Hello
It's really a pain in the a**!
Remove the center part of the bushing by drilling the rubber, then use a saw to split the metal shell, after that you can just tap it out.
My Web Site
DLF is offline
post #6 of 8 (permalink) Old 01-17-2010, 02:19 PM
tbirdtess's Avatar
Thats what I had in mind. Was looking for another way.
They would not press out.
351W 2bbl.
C-4 Auto
3.90 open rear
post #7 of 8 (permalink) Old 01-17-2010, 02:22 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I can't speak for the rears, but when I replace front control arm bushings with bushings that have the metal shell, I beat a dent into the shell with an air hammer, then the airhammer will almost always push it right out. Hammer and chisel will work too, but maybe not as quick!
-Rob
-Rob
Rob is offline
post #8 of 8 (permalink) Old 02-03-2010, 02:01 AM
FWIW, I don't remember super clearly, but I changed all those bushing on mine. What I remember doing is a big C clamp to push some of them out and using a press on others; it was an easier job than I thought it was gonna be!
