Rear swaybar bushings - TCCoA Forums
post #1 of 4 (permalink) Old 01-15-2010, 11:51 AM Thread Starter
I am having engine problems with my Nissan. So I have to get this Tbird back together ASAP as I have no vehicle now.
Went to install the new Raybestos rear swaybar bushings, and discovered that these things dont seem to have the "slit" in them like the front bushings and all other swaybar bushings I have ever seen. Do I need to cut them to install, doesn't seem right that I should...
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #2 of 4 (permalink) Old 01-15-2010, 12:06 PM
Are they too tight to slide in from the end?
69 F100 LWB w/460 Engine
post #3 of 4 (permalink) Old 01-15-2010, 01:21 PM Thread Starter
Yeah I am pretty sure I will screw them up sliding it over the squarish part where the endlinks connect. Its not even close even after smashing it down squarish. Looks like I have to cut them.
All Glory to God!
RIP JOHNNY LANGTON
-MODS-
96_LX is offline
post #4 of 4 (permalink) Old 01-15-2010, 10:08 PM
carcrz's Avatar
dont cut them they will fit over the square part of the swaybar try using some WD40 to help with the insertion
1989 THUNDERBIRD
3.8 LITER
BLOWN HEAD GASKETS
H\G fixed
carcrz is offline
