Back on road, pesky clunking... - TCCoA Forums
post #1 of 2 (permalink) Old 01-16-2010, 07:51 PM Thread Starter
Well I got my 96 LX back on the road about 30 mins ago. After the front end rebuild, about 95% of the noises it used to make are gone. But there is one pesky clunk left. Otherwise it is worlds! better than it was before I tore it down.
I retorqued the front subframe and all but one bolt were a bit (1/2 turn or less) loose. New swaybar bushings and endlinks, lower control arms/ball joint, Ford OEM strut rod bushing kit at frame as well as LCA, and new outer tie rods, of course all torqued to spec.
The driver side suspension is silent and functions flawlessly. I got down to the alignment shop to late to get it aligned, but the wheel is just slightly off center and feels very tight - I must have got it very close. But the passenger side still makes a slight clunk on rough roads. The sound appears to be coming from the top of the shock tower and is only apparent when the suspension travel is fully (or close to) compressed i.e. bad potholes. Best way I can describe it is a slapping clunk noise. Almost like the shock is bouncing up and down with slack.
Any ideas on where to go from here would be appreciated.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #2 of 2 (permalink) Old 01-17-2010, 01:55 AM
end link could be loose?
