Need Help / Opinions - TCCoA Forums
post #1 of 19 (permalink) Old 01-17-2010, 12:57 PM Thread Starter
cougar_fan's Avatar
This thread concerns strut rod bushings. Search really didn't come up with the information that I was looking for.
My strut bushings (ones on the arm and ones to the frame) are SHOT. I mean absolutely gone. Search helped lead me to the diagnosis . . . Clunking over bumps, in the turns, and when on the brakes.
SO, here are the questions. What would you recomend as replacement bushings? I'm not needing anything crazy, just a nice bushing that is going to hold up. Keep in mind that I need both bushing. Also, being that I want to do this myself (I hate people I don't know working on my car) am I going to need a press to get these in? We'll be putting it on the lift at home, but how big of a biatch are these gonna be? Any tips, pointers, or know how is GREATLY appreciated. I'm doing this soon so I can make the cruise in April, so any info would help me out considerably. Thanks y'all.
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #2 of 19 (permalink) Old 01-17-2010, 03:42 PM
Never had to replace mine before, but from the passive reading I've done here in the past I've been under the impression that the OE rubber bushings are best.
Again, speaking from what I've read, not from experience. I may be corrected.
post #3 of 19 (permalink) Old 01-17-2010, 03:45 PM
The Band, not the Disease!
AnthraxBird's Avatar
OEM bushings are fine. Usually hold up 100,000 miles plus. Replace all 4. Also, it would be easier to replace the UCA's and LCA's at this time, also.. because you are going to need to get the car aligned after you do this!
AnthraxBird is offline
post #4 of 19 (permalink) Old 01-17-2010, 04:34 PM Thread Starter
cougar_fan's Avatar
Gotcha Anthrax. That is already in the plan. Any guess as to the quality of aftermarket bushing such as Moog, etc . . .
post #5 of 19 (permalink) Old 01-17-2010, 06:30 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Most control arms come with bushings and balljoints installed. Moog,TRW and others can be had for a good price at rockauto.com, there a discount code thread on this site.
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #6 of 19 (permalink) Old 01-17-2010, 07:54 PM Thread Starter
cougar_fan's Avatar
Beamer,
Thanks for the heads up on that code By the way, why aren't you coming to the cruise in April?
post #7 of 19 (permalink) Old 01-17-2010, 08:12 PM
Family vacation headed the other way. LOL
post #8 of 19 (permalink) Old 01-17-2010, 10:48 PM
SuperNewbie
supergordo's Avatar
The strut rod bushings do not come installed on the lower control arms from any supplier. Only use the Ford Bushings. There are a few other threads on this on the site here about this. Aftermarket bushings don't stand up.
The part number is E9SZ-3A140-A and E9SZ-3A140-B if you want to do both sides you need to order both part numbers. One is a front the other the back.
Its not that hard of a job. You'll be fine doing it on your own.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #9 of 19 (permalink) Old 01-17-2010, 11:14 PM
my ****ty ass oe brand had them on
You can see them in the pic, link here: http://forums.tccoa.com/showthread.php?t=126409
post #10 of 19 (permalink) Old 01-17-2010, 11:37 PM
I just installed new Ford Bushings at the frame and control arm, as well as everything else besides upper control arms (2 yrs old) oh wow does my car drive like brand new
Don't cheap out on the strut rod bushings.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #11 of 19 (permalink) Old 01-18-2010, 01:24 AM
Yeah there have been a few aftermarket bushings that have failed around the boards. MOOG is fine for Control arms and such, they are EXCELLENT. Correct me if im wrong, but aren't MOOG and Motorcraft control arms made by the same supplier?
post #12 of 19 (permalink) Old 01-18-2010, 02:54 AM
I was under the impression that Motorcraft and TRW suspension parts are identical, but Moog is its own.
post #13 of 19 (permalink) Old 01-18-2010, 01:28 PM Thread Starter
cougar_fan's Avatar
Called up the local Ford Dealer. I have (2) E9SZ-3A140-A heading my way. Thanks to supergordo for the heads up. I'll get it on the left this weekend and tackle it, then head over to the shop for an alignment. I'm intrigued to see just how different it is going to drive
post #14 of 19 (permalink) Old 01-18-2010, 02:10 PM
Don't forget the E9SZ-3A140-B part, one goes in the front and one in the back!
tbirdguy is offline
post #15 of 19 (permalink) Old 01-18-2010, 03:05 PM
They're not on your lower control arms, the strut rod bushings go in the huge hole near your LCA ball joint.
skootboy is offline
post #16 of 19 (permalink) Old 01-18-2010, 03:24 PM Thread Starter
cougar_fan's Avatar
Whoa, alomost missed that one I'm in such a rush to get this done I totally forgot about that. Thanks tbirdguy I appreciate that very much!
post #17 of 19 (permalink) Old 01-18-2010, 03:53 PM
No problem sir! pay attention to the markings on the bushings too, one is marked "rear" on the rubber to face the rear of the car. They are not interchangeable.
tbirdguy is offline
post #18 of 19 (permalink) Old 01-18-2010, 03:57 PM
I thought that was for the sway bar not the strut?
post #19 of 19 (permalink) Old 01-18-2010, 04:12 PM
There were special SC specific TRW control arms that came with strut rod bushings, available from Advance. The arms and bushings were under $60 IIRC. I believe those are gone for good now, and no control arm comes with strut rod bushings. The only real choice is spending $50 for a set of OEM ford rubber, they will last you another decade. Anything else is like putting small chocolate doughnuts there, they will barely last a year.
tbirdguy is offline
