I think my bearings are bad. - TCCoA Forums
post #1 of 8 (permalink) Old 02-03-2010, 11:12 AM Thread Starter
chris g's Avatar
Send a message via Yahoo to chris g
Red face I think my bearings are bad.
i was checkin my front wheel bearings yesterday and i think they might need to be replaced. i jacked the front end up and could wiggle both front tires some. i am guessin it's time to replace them they have 250,000 miles on them and have never been changed.jus wanted to make sure i checked them right.. thanks guys!
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #2 of 8 (permalink) Old 02-03-2010, 12:11 PM
If you can move the wheel by grabbing the top and bottom (or front and rear) and rocking it without moving the suspension components then your bearing is toast.
When I replaced one a few months ago it ran me $70.01 with a new nut from RockAuto with the 5% discount.
post #3 of 8 (permalink) Old 02-03-2010, 12:42 PM
I'd recommend you replace them with Timkin bearings - but make sure you don't have bad ball-joints instead!
post #4 of 8 (permalink) Old 02-03-2010, 01:08 PM
just replace the entire hub......don't waste the time trying to replace just the bearings.
post #5 of 8 (permalink) Old 02-03-2010, 01:08 PM
That's what I had to replace (ball joints). Bearings were fine, but I had to replace both upper and lower ball joints (uppers can only get with UCA, lower I changed just the ball joint).
post #6 of 8 (permalink) Old 02-03-2010, 08:21 PM
Yeah, when I said to replace the bearings with Timkin bearings, I of course meant the entire hub assembly!
post #7 of 8 (permalink) Old 02-15-2010, 02:53 PM
crash00527's Avatar
Send a message via AIM to crash00527
i was goona say.. don they came as one?
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #8 of 8 (permalink) Old 05-20-2010, 11:41 PM
My 1994 Bird has a little play 12:00 oclock -6:00oclock..on front drivers side...very little...the paseenger side has none...or very little....I see its has a wierd nut metal housing on it...I just need to tighten just a li bit....whts the deal on this ???thnx for any info.....
woody95124 is offline
