Front Suspension Rebuild and SC Suspension Swap + Collision Repair - TCCoA Forums
post #1 of 35 (permalink) Old 02-23-2010, 10:19 PM Thread Starter
Raptor22's Avatar
As many of you know I was involved in an accident last month in which something broke in my steering and I hit a center island median at 40 MPH. I have decided that that is an excuse to rebuild my suspension and do an SC suspension swap. I got the front subframe from an SC and I am replacing all suspension and steering components with new Moog parts. I have Eibach springs on all four factory Tokico struts (from the same SC) and the ARC actuators that I am going to run to a switch in the cabin so my ride control works. I am also buying all new rubber all around (Yokohama Avid TRZs) and a new fender, corner light, and marker light to fix what I broke in the collision. I am also replacing the chrome bump strips in the bumpers because they are cracked and peeling, but that doesnt really affect my suspension or my collision repair. I am really stoked because this will be a big handling upgrade and practically eliminate body roll. I will update the post with pics as I do the rebuild and install.
The starting point:
My car is going to look alot like this one when I am finished, but crimson of course.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 35 (permalink) Old 02-23-2010, 11:03 PM
....but with wire wheel hub caps.
post #3 of 35 (permalink) Old 02-23-2010, 11:09 PM Thread Starter
Raptor22's Avatar
Yeah well, its a conundrum.
I found one real cheap and with new rubber (not whitewalls either) and the Eibach lowering springs its going to look badass and handle even better. I think I can make the wheel covers cool again.
Raptor22 is offline
post #4 of 35 (permalink) Old 02-23-2010, 11:14 PM
decipha's Avatar
SC suspension and LX suspension are pretty much the same only difference is that the SC got stiffer bushings in the lower control arm and that they come with the longer shocks that make the car sit higher as well as the electric struts
thats right the sc stock sits higher than the lx stock, doesn't appear so because of the gfx but thats just deceiving trust me I own 6 supercoupes and 1 lx (not for long) not a big deal for you since you have the eibach's
moog stuff is good except for the strut rod bushings, be sure you get either the ford replacements or the rubber replacements from autozone, I've had good luck with those
I've personally had the blue moog strut rod bushings blow out on me in my red 90 5spd about 2 years ago doing 70 on the interstate coming around an interchange to another instate, was not fun to say the least
ebay used to have the clear corner set for like $25 when i ordered mine last year
general rule of thumb is to reduce body roll in the front you need to stiffen the rear
and for any type of handling those stock wheels need to go
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #5 of 35 (permalink) Old 02-23-2010, 11:17 PM
decipha's Avatar
i just looked over the pic... why is the left side of the hood low and the driver side so much higher??
did you check the header panel? that's that panel that all the headlights and corner lights bolt to, that maybe cracked, if so they have a plastic type on eBay that's 1000x better than the original fiberglass type
decipha is offline
post #6 of 35 (permalink) Old 02-23-2010, 11:19 PM Thread Starter
Raptor22's Avatar
Thanks for the informative post man, I am going with new control arms that already have the bushings in them, it was actually cheaper than the bushings individually. I got the rear shocks and springs too and I am going to use those. The rims are temporary to longer term right now as I am getting new tires. My dads 280Z handles great with 215/70R15 tires on it, it shouldnt be too bad. I am not going for autocross type performance anyways, just an improvement over stock which I am going to get. As far as the corner light I wanted clear corners but I decided against them and just got a factory one.
What I am most excited about is rigging up the ARC... er... MRC. (Manual Ride Control)
Raptor22 is offline
post #7 of 35 (permalink) Old 02-24-2010, 08:23 AM
MATLOCK's Avatar
ditch the wire hubs dude
All the ponies below are located at my ranch in INDIANA if anyone wants to go for a ride...haha
1989 XR7 SC 5-speed
1996 Bronco on 33's
1995 Mustang GT mild 302 Quicktime Turbo kit 543hp on 9lbs
MATLOCK is offline
post #8 of 35 (permalink) Old 02-24-2010, 11:00 AM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
I never found any control arms that come with the strut rod bushing.
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #9 of 35 (permalink) Old 02-24-2010, 12:46 PM
byrd_of_thunder's Avatar
Send a message via AIM to byrd_of_thunder Send a message via MSN to byrd_of_thunder Send a message via Yahoo to byrd_of_thunder
i really like that color. how does it look at night? i wonder why ford did away with the cornering lamps
Nick
Byrd_of_Thunder
2012 Ford Focus SE Hatchback
**1997 Ford Thunderbird LX - RIP**
byrd_of_thunder is offline
post #10 of 35 (permalink) Old 02-24-2010, 04:41 PM
Bradone's Avatar
Definitly. Needs "Baby Moons"!
[email protected] (engine/trans is stock)
Bradone is offline
post #11 of 35 (permalink) Old 02-24-2010, 07:30 PM Thread Starter
Raptor22's Avatar
These are the ones that I bought:
MOOG Part # K80053 More Info {Control Arm w/Ball Joint}
Frt Susp; Lower; LH; Incl. Arm to frame bushing; Incl. Arm to strut bushing
$63.79 $0.00 $63.79
MOOG Part # K80055 More Info {Control Arm w/Ball Joint}
Frt Susp; Lower; RH; Incl. Arm to frame bushing; Incl. Arm to strut bushing
$63.79 $0.00 $63.79
It looks great at night I like it, is is going to look awesome when lowered.
Ford probably thought the cornering lamps were a "better idea for the 80s" and not for the 90s so they did away with them...
http://www.youtube.com/watch?v=BYl-gVCAyJ0
Raptor22 is offline
post #12 of 35 (permalink) Old 02-25-2010, 02:01 AM
Originally Posted by Raptor22 View Post
better ideas huh?
Nick
Byrd_of_Thunder
post #13 of 35 (permalink) Old 02-25-2010, 07:40 AM
MATLOCK's Avatar
found some....lol
1989 XR7 SC 5-speed
1996 Bronco on 33's
MATLOCK is offline
post #14 of 35 (permalink) Old 02-25-2010, 09:40 AM Thread Starter
Raptor22's Avatar
found some....lol
Haha. Awesome.
Raptor22 is offline
post #15 of 35 (permalink) Old 02-25-2010, 03:17 PM
hey raptor how far are you from sac?
Nick
Byrd_of_Thunder
post #16 of 35 (permalink) Old 02-25-2010, 03:48 PM
btw, they are shocks....not struts.
post #17 of 35 (permalink) Old 02-25-2010, 08:22 PM Thread Starter
Raptor22's Avatar
Davis.
Raptor22 is offline
post #18 of 35 (permalink) Old 02-25-2010, 09:08 PM
tbirdtess's Avatar
offset?
found some....lol
Hi
those are going to stick out.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #19 of 35 (permalink) Old 02-25-2010, 09:20 PM Thread Starter
Raptor22's Avatar
Originally Posted by tbirdtess View Post
Hi
I think they look badass, haha. Im going to see how the wire wheels look first though...
Raptor22 is offline
post #20 of 35 (permalink) Old 02-25-2010, 11:58 PM
Davis.
DUDE you're closer than i thought you were. for some reason i was thinking you were closer to the bay. you're only about a half hour from me
Nick
Byrd_of_Thunder
post #21 of 35 (permalink) Old 02-26-2010, 12:06 AM Thread Starter
Raptor22's Avatar
Yeah, 12 miles from Downtown Sacramento. We're neighbors...
Raptor22 is offline
post #22 of 35 (permalink) Old 02-26-2010, 01:15 AM
really tho. i'm in north highlands, about the same distance east as you are west. if i can ever get some money flowing in we should get some project collaboration going
Nick
Byrd_of_Thunder
post #23 of 35 (permalink) Old 02-26-2010, 09:38 AM Thread Starter
Raptor22's Avatar
Hell yeah man. Im up for that. Whereabouts North Highlands? Up Madison Avenue? I go over there all the time.
Raptor22 is offline
post #24 of 35 (permalink) Old 02-26-2010, 01:21 PM
elkhorn and walerga. i'm about 5 minutes away from madison
Nick
Byrd_of_Thunder
post #25 of 35 (permalink) Old 02-26-2010, 05:04 PM Thread Starter
Raptor22's Avatar
Oh wow, farther than I thought.
I go up that way every once in a while...
Raptor22 is offline
post #26 of 35 (permalink) Old 02-26-2010, 10:40 PM
i'm going to be moving to elk grove in 2 months, hopefully to a place with a garage so i can get some much needed work done on the bird.
Nick
Byrd_of_Thunder
post #27 of 35 (permalink) Old 02-26-2010, 11:11 PM Thread Starter
Raptor22's Avatar
Awesome, Elk Grove is nice.
Raptor22 is offline
post #28 of 35 (permalink) Old 03-19-2010, 11:05 PM Thread Starter
Raptor22's Avatar
Update:
I dropped the subframe today. I completely rebuilt an SC subframe I got from a dismantler with new Moog control arms, stabilizer bar links, tierod ends, and bushings. I am going to raise the new one in on monday along with my Tokico SC shocks and Eibach drop springs. I have Tokico SC shocks (thanks speed95!) I am putting on the rear. I am currently looking for the matching Eibach drop springs for the rear and am obtaining them. I bought some new tires (Yokohama AVID TRZs, 215/70 15s) that I am putting on the stock rims. However they arent really stock because I am getting them powder coated and I am restoring the wheel covers. I got my new fender back today, I had it painted by Woodland Body Works in Woodland California, they do great work. I have new corner and marker lights and new chrome bumper strip.
I will post pictures up on here when the car is done.
Oh, I almost forgot. I am also getting together with my buddy who is gonna help me direct wire the ARC system to a switch in my cabin so the electronic shocks work.
Raptor22 is offline
post #29 of 35 (permalink) Old 03-20-2010, 10:31 AM
Where did you get the chrome strip for the bumper?? Got a link?? Keep up the wrenching!!
post #30 of 35 (permalink) Old 03-20-2010, 12:35 PM Thread Starter
Raptor22's Avatar
Thanks man!
Heres how I found the strip. Go to RockAuto and go to: Ford / 1989 / Thunderbird / Body - Exterior / Bumper Trim - Molding
I ordered both the front and rear strip but they had to cancel the order for the rear one because they had none in stock...
Raptor22 is offline
