What is the bushing called that goes here - TCCoA Forums
post #1 of 24 (permalink) Old 02-27-2010, 04:43 PM Thread Starter
ghost_hunter_rick is offline
post #2 of 24 (permalink) Old 02-27-2010, 05:07 PM
Originally Posted by ghost_hunter_rick View Post
Strut rod LCA bushing - or rear strut rod bushing.
Search for the proper Ford part numbers here on the forums.
RalphP is offline
post #3 of 24 (permalink) Old 02-27-2010, 06:10 PM
Raptor22's Avatar
Wait, thats the front lower control arm. Thats where the torsion bar link goes through. I was going to replace all my bushings but I just decided to get a whole new control arm with bushings in it, it was cheaper. I cant find the name of the bushing though, just looking on RockAuto...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #4 of 24 (permalink) Old 02-27-2010, 09:39 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
The name of that bushing is strut rod bushing(at arm) youll need the bushing(at frame) also and it does not come with any LCA
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #5 of 24 (permalink) Old 02-27-2010, 09:43 PM
Raptor22's Avatar
The strut rod bushing is the next one to the left, thats the torsion bar bushing. My new Moog control arms came with them. I would know, I put them on yesterday...
Raptor22 is offline
post #6 of 24 (permalink) Old 02-27-2010, 09:46 PM
There are no torsion bars on these cars.
post #7 of 24 (permalink) Old 02-27-2010, 09:51 PM
Raptor22's Avatar
The torsion bar link tension strut. Not the strut rod bushing which is next to it...
Raptor22 is offline
post #8 of 24 (permalink) Old 02-27-2010, 09:59 PM
If your sway bar link is going through there you have some serious problems. I am not talking about the strut bushing, which yes is the next one down, I am talking about the gaping hole in the LCA which is where the strut ROD and bushing go. Your control arm you installed yesterday had a bushing in that hole??? Heres a pic to clarify:
post #9 of 24 (permalink) Old 02-27-2010, 10:01 PM
Yeah again, there are no torsion bars.
In the picture in post 1 from left to right: LCA to K member bushing - shock mount - strut rod bushing - ball joint.
post #10 of 24 (permalink) Old 02-27-2010, 10:06 PM
Raptor22's Avatar
Maybe its all coming down to names. My Haynes manual calls it a Tension strut. Its the bar that has a dogleg in it. The dogleg is flat to put a backup wrench on to impact the gynormous nut off of it...
The strut rod (the rod with the strut on it...) is the next hole down...
Raptor22 is offline
post #11 of 24 (permalink) Old 02-27-2010, 10:12 PM
The only struts on these cars are the strut rod(tension strut). The mount next to that is the SHOCK mount.
post #12 of 24 (permalink) Old 02-27-2010, 10:26 PM
Raptor22's Avatar
Interesting.
Raptor22 is offline
post #13 of 24 (permalink) Old 02-28-2010, 12:29 AM
byrd_of_thunder's Avatar
Send a message via AIM to byrd_of_thunder Send a message via MSN to byrd_of_thunder Send a message via Yahoo to byrd_of_thunder
Nick
Byrd_of_Thunder
2012 Ford Focus SE Hatchback
**1997 Ford Thunderbird LX - RIP**
byrd_of_thunder is offline
post #14 of 24 (permalink) Old 02-28-2010, 10:12 AM
Actually, no - you're not supposed to put ANYTHING on the flat, according to the Ford service manual.
There is only one strut on each side - the strut rod, which goes through that hole.
I suggest checking the Ford Service Manual (I picked mine up on eBay for about $20) for the actual proper manufacturer's terms, instead of the wrong terms some people toss about.
RalphP is offline
post #15 of 24 (permalink) Old 02-28-2010, 11:14 AM
I just posted a thread recently about the Ford OE parts that go there; I just got mine from the dealer:
http://forums.tccoa.com/showthread.php?t=127556
post #16 of 24 (permalink) Old 02-28-2010, 03:31 PM
Raptor22's Avatar
Thanks man, all I have is my Haynes manual. It said to put the back up wrench on the flat part closest to the LCA and farthest from the bend in the strut rod...
Raptor22 is offline
post #17 of 24 (permalink) Old 02-28-2010, 04:41 PM
The Haynes manual is pretty good at times, but it's not prefekt
Example: The Ford service manual says, "To do xxx, you need to use special tool 47XK6Z".
The Haynes manual will say: "To do xxx, you need to use special tool 47XK6Z. However, you can substitute a 2x4, four screws, and a rabid wombat by ... "
RalphP is offline
post #18 of 24 (permalink) Old 02-28-2010, 05:01 PM
Raptor22's Avatar
Bwahahhahaha. Here in Peoples Republic of Amerika we use special took 47XK6Z, back in Soviet Russia we use rabid wombat.
Raptor22 is offline
post #19 of 24 (permalink) Old 02-28-2010, 05:07 PM
Just checked my Ford service manual and it you have to use the flat on the strut rod other wise how would you go about removing it??, it shows a picture and says keep the wrench on the flat away from the area where the bend is in the strut rod.
I geuss it could damage/bend the rod at its weakest point (the bend) and screw up the geometry idk
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #20 of 24 (permalink) Old 02-28-2010, 06:20 PM
The important thing is not to put divots in the metal AT the bend; you can use the flats AWAY from the bend.
If you put a big gouge there, it will form a crack at the bend, eventually.
It's called a "stress riser".
http://en.wikipedia.org/wiki/Stress_concentration
post #21 of 24 (permalink) Old 03-01-2010, 01:39 PM Thread Starter
It is the strut rod bushing even though it dosent have anything to do with the strut
post #22 of 24 (permalink) Old 03-01-2010, 01:51 PM
The shock isnt a strut. The strut rod is called so because it acts as... a strut (it ties the LCA to the K member, resisting compression or expansion between those points).
post #23 of 24 (permalink) Old 03-01-2010, 07:33 PM
Thats what i was getting at about being able to use the flats just not at the bend. interesting wiki article did'nt think a little gouge from a wrench would be able to hurt that strut rod. its pretty substantial. I learn something new everyday
Tbird64 is offline
post #24 of 24 (permalink) Old 03-01-2010, 08:48 PM
Imagine how much sh*t broke before someone figured this out...
