school me some sway bars - TCCoA Forums
post #1 of 11 (permalink) Old 02-28-2010, 10:03 PM Thread Starter
BlkBrd95's Avatar
Send a message via MSN to BlkBrd95
i'm curious about putting a new sway bar on my car. just planning for the future more or less... i'm looking for pro's and con's... what's better yadda yadda yadda... between. stock sway bars both front and rear and say the 1 1.4", 1 3/8" front sway bars... and same for the rear. any info would be appreciated guys. thanks
2001 Ford F-150 Supercrew
1995 Thunderbird LX
BlkBrd95 is offline
post #2 of 11 (permalink) Old 02-28-2010, 10:06 PM
Why don't you do your homework.
... Search is your friend.
post #3 of 11 (permalink) Old 02-28-2010, 10:30 PM
Is this english?
post #4 of 11 (permalink) Old 02-28-2010, 10:50 PM Thread Starter
BlkBrd95's Avatar
Is this english?
You know what! You could've simply answered my question instead of being a smartass. It's not needed and not appreciated!
1995 Thunderbird LX
BlkBrd95 is offline
post #5 of 11 (permalink) Old 02-28-2010, 11:07 PM
kpthefatty's Avatar
basically, the best bet is to stick with the 1-1/4" bars if you plan on putting it on the road. i have also posed this question recently. i have yet to put these on my car. however, the combo of a stiffer bar and the stiffer poly bushings should make a large difference.
kpthefatty is offline
post #6 of 11 (permalink) Old 02-28-2010, 11:30 PM
swapped to 1.25 front and rear and I like it.
post #7 of 11 (permalink) Old 03-01-2010, 12:02 PM
tbirdtess's Avatar
Main purpose?
Hello
How is this car driven?
Street, drag?
curvy roads? just straight?
If you drag race mostly go smaller. less weight.
A 1 1/4" front solid bar is heavy.
I have a front 1 3/8" in my race car, 1/2 mile asphalt.
.96 rear bar.
Alot of curvy roads go with bigger bars. Most like to go slightly bigger in front.
Early SC are nice, larger than later bars.
Also install spring tower braces, Front & Rear. If not you could crack the fire walls.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #8 of 11 (permalink) Old 03-01-2010, 12:26 PM Thread Starter
BlkBrd95's Avatar
kp, splattered, tbird. thank you for the info! the car is driven on city streets alot and long road trips. so with that would i just be better off replacing all stock bushings with poly bushings?
1995 Thunderbird LX
BlkBrd95 is offline
post #9 of 11 (permalink) Old 03-01-2010, 01:23 PM
poly bushings are junk i road course mine and i run stock ford ford bushing, well replacments and ive got the new redesigned addco bar installed on my car, this bar should fit perfect unlike the other bar this is and exact replica of the stock bar but bigger the one they used to sell does not fit properly it works so they have redesigned it
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #10 of 11 (permalink) Old 03-01-2010, 04:01 PM
kpthefatty's Avatar
blackbird, i would say try the 1-1/4 in the rear. and see what you think. it is a simple install. the front install is a PITA. so just try the rear for now
post #11 of 11 (permalink) Old 03-01-2010, 05:59 PM Thread Starter
BlkBrd95's Avatar
Ok thanks kp! When money permits I'll look Into swapping sway bars out. Just spent some money on the birdie. New uca's, lca's, sway bar links in the rear and some '03 cobras from the custom wheel shop!
Robert... Why do you say the poly bushings are crap?
1995 Thunderbird LX
BlkBrd95 is offline
