Replacing ARC shocks/springs, what is compatible? - TCCoA Forums
post #1 of 9 (permalink) Old 03-03-2010, 12:56 PM Thread Starter
svtfiend@yahoo.com's Avatar
so, i am looking to replace all the springs and shocks/struts on my SC and don't want to cough up 600 bucks for the Illuminas. I have been looking trying to find info on what will swap in and it looks like the KYB gr2s will bolt right in to the super coupe? is this correct? anyone no of other struts that will work?
some say they will all fit, some people say only certain brands are compatible. thanks guys!
__________________
this is also posted in SC section. thought i might get better replies here!
1991 Super Coupe -
Performance=5.0 H.O. w/M5R2 5speed, 3.27 gears w/CF TracLoc,95 Cobra intake, 75mm Power throttle body, fenderwell CAI, C&L 73mm mass air w/24# injectors, FRPP E-Cam,Trickflow spring kit & Crane 1.7 roller rockers on stock E7s, MAC shorty headers, Flowmaster cat back w/hiflow cats, MSD plugs, coil, wires, electric cooling fan, 190lph Walbro fuel pump, BBK pulleys, and a B&M shifter. Drilled/slotted rotors, power brake conversion, Tokico Blues, Eibach springs, tons of poly, T4MO ecm
post #2 of 9 (permalink) Old 03-03-2010, 01:18 PM
DLF
DLF's Avatar
If you want to retain the ARC function, your only choices are stock or the Illuminas.
If you don't care about the ARC, than any shock for the T-Bird will fit. I went with Koni's.
My Web Site
DLF is offline
post #3 of 9 (permalink) Old 03-03-2010, 07:19 PM
Ive been looking for this info EVERYWHERE(couldnt post here for a couple days).As long as the servos remain hooked up,,,,the steering/brake sensors wont see a problem,correct?Can the ARC springs be reused on the new struts?
Thanks a ton for this info guys!!!
925.0XR7 is offline
post #4 of 9 (permalink) Old 03-03-2010, 09:17 PM Thread Starter
not looking to keep the ARC. some were saying the mounts were different and you needed to cut off your original ARC mount and somehow use it on the aftermarket shock! i couldnt figure out why it would be different when the control arms,etc are the same.
do you need to change the ANYTHING ELSE? if not, that is sweet.
925 xr7-as far as i know the springs are the same as the v8s, so they should be fine.
anybody know which springs drop the car 3/4"-1"?
1991 Super Coupe -
post #5 of 9 (permalink) Old 03-03-2010, 09:49 PM
DLF
DLF's Avatar
I unplugged the fuse for the ARC to stop the light from flashing, but other than that, there are no changes required. I also unplugged and removed the ARC servos.
My Web Site
DLF is offline
post #6 of 9 (permalink) Old 03-04-2010, 08:58 PM
what about something like this:
http://www.racinglab.com/tein-edfc-edk05-12120.html
Which is run by:
http://www.racinglab.com/tein-edfc-edk04-k4469.html
Is this too rice?
IIRC, the stock SC ARC controllers only three position?
The Koni's seem to be continuously adjustable...
post #7 of 9 (permalink) Old 03-04-2010, 10:17 PM
DLF
DLF's Avatar
Stock, the Super Coupe ARC has two positions.
If there was something that would work with Koni's, that would be sweet.
My Web Site
DLF is offline
post #8 of 9 (permalink) Old 03-04-2010, 10:27 PM
rbrown's Avatar
What didn't like all the clicky clicky clicky. LOL
rbrown is offline
post #9 of 9 (permalink) Old 03-05-2010, 07:13 PM
I'm going to start looking for parts; this looks like a cool summer project...
It would be nice to buy off the shelf stuff; I'll research this further.
Konis are on sale right now, BTW; $513 to me.
