Strut rod nuts help - TCCoA Forums
post #1 of 6 (permalink) Old 03-06-2010, 03:12 PM Thread Starter
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Strut rod nuts help
Both nuts seem to be rusted solid, tried impact and torch. Anybody have a suggestion.
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #2 of 6 (permalink) Old 03-06-2010, 03:17 PM
tbirdtess's Avatar
blaster
Hello
I used PB Blaster on them. I let them soak for a couple on days, Sorry.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 6 (permalink) Old 03-06-2010, 03:57 PM
Put the car on a lift and use 2 of the hugest wrenches you can and double wrench them LOL. PB blaster is a must but I read here 50% trans fluid 50% acetone worked the best to break seized nuts loose.
post #4 of 6 (permalink) Old 03-06-2010, 09:37 PM
Make sure you have one of those big adjustable wrenches holding the strut rod against the concrete. Make sure the wrench is on the appropriate spot in on the flat as per the service manual. What kind of impact are you using? Nothing under the "Earthquake" or "thundergun" level is going to touch that bolt. Also, an impact is at a disadvantage because the the strut rod moves in the bushings and absorbs blows.
Also a 24" breaker bar with that adjustable wrench should do the trick. That large nut is very hard to heat.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #5 of 6 (permalink) Old 03-06-2010, 09:55 PM
decipha's Avatar
i guess that doesn't apply to us southern non-snow seeing folks, I never had any trouble getting the strut rod bolts off on any of my cars... hmm
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #6 of 6 (permalink) Old 03-06-2010, 10:59 PM Thread Starter
Well after enough cussing I went to my dad's work(Praxxair), and borrowed the mechanics 3/4" drive gun, worked great!!
Thanxs for all the [email protected]@
