Lower reac control arm Bushings - TCCoA Forums
post #1 of 17 (permalink) Old 03-07-2010, 11:01 AM Thread Starter
tbirdtess's Avatar
Lower rear control arm Bushings
Hello
Well I am starting my Rear Suspension upgrade.
First New lower rear control arm bushings.
the are made by DLF. A member here.
Shown are the old bushings I removed & the new one's.
I will press them in soon.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 17 (permalink) Old 03-07-2010, 02:28 PM
DLF
DLF's Avatar
If you have one, it's not a bad idea to run a 1 1/4" drill bit (carefully!) through the bushings after you bang them in. You should be able to put them in with just a dead blow mallet, I do.
My Web Site
DLF is offline
post #3 of 17 (permalink) Old 03-07-2010, 05:59 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Man that control arm looks like its been out in the rain for a while. You might wanna throw that in a blast cabinet and spray a little paint on it.
Nice upgrade though! Keep up the wrenching!
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #4 of 17 (permalink) Old 03-07-2010, 06:04 PM
DLF
DLF's Avatar
Cast iron looks like crap no matter what you do, but it'll last just about forever. One reason I switched to the Mark VIII LCA's.
My Web Site
DLF is offline
post #5 of 17 (permalink) Old 03-07-2010, 07:52 PM
+1 ...and lose a little weight too!
post #6 of 17 (permalink) Old 03-07-2010, 11:11 PM
byrd_of_thunder's Avatar
Send a message via AIM to byrd_of_thunder Send a message via MSN to byrd_of_thunder Send a message via Yahoo to byrd_of_thunder
do you have to use the mark knuckles with the LCAs since the outer ears are different between the bird and mark?
Nick
Byrd_of_Thunder
2012 Ford Focus SE Hatchback
**1997 Ford Thunderbird LX - RIP**
byrd_of_thunder is offline
post #7 of 17 (permalink) Old 03-07-2010, 11:14 PM
DLF
DLF's Avatar
The knuckles are the same, they just mount with different bolts.
My Web Site
DLF is offline
post #8 of 17 (permalink) Old 03-07-2010, 11:25 PM
i see
Nick
Byrd_of_Thunder
post #9 of 17 (permalink) Old 03-07-2010, 11:30 PM
DLF
DLF's Avatar
i see
Look HERE.
DLF is offline
post #10 of 17 (permalink) Old 03-07-2010, 11:38 PM
very helpful thanks
Nick
Byrd_of_Thunder
post #11 of 17 (permalink) Old 03-09-2010, 07:08 PM Thread Starter
tbirdtess's Avatar
Pressed
Hello
Well I pressed the bushings in place. Now I have to drill for the grease fittings.
Don't see using a hammer.
3-21-10 Drilled for the grease fittings. Easy!
Put the inner pins
Should I grease before or after install on the car?
pcool
351W 2bbl.
C-4 Auto
3.90 open rear
post #12 of 17 (permalink) Old 04-16-2010, 08:33 AM Thread Starter
tbirdtess's Avatar
update
Hello
Well I have the left side lower arm & knuckle ready to install.
brakes are next.
351W 2bbl.
C-4 Auto
3.90 open rear
post #13 of 17 (permalink) Old 04-16-2010, 11:12 AM
DLF
DLF's Avatar
?? You have the right side knuckle on the left side LCA.
My Web Site
DLF is offline
post #14 of 17 (permalink) Old 04-16-2010, 12:19 PM Thread Starter
tbirdtess's Avatar
Hello
Well it is a test fit. apparently the knuckles are labeled wrong. lol
Why are the 90 rear brake lines so much more than the 96's??
I will be doing the other side(knuckle) on saturday.
redrilling the rotor also, both sides.
351W 2bbl.
C-4 Auto
3.90 open rear
post #15 of 17 (permalink) Old 04-27-2010, 02:38 AM
DLF
DLF's Avatar
After installation.
My Web Site
DLF is offline
post #16 of 17 (permalink) Old 04-27-2010, 12:59 PM Thread Starter
tbirdtess's Avatar
Grease
Hi
Yes, I waited until I installed them on the car. They are still loose.
I need to align the wheels first(string the car).
Then i will regrease.
The only problem installing was that the pumpkin bracket.
I had to loosen upper bolt to slide the side bolts threw.
I also upgraded to rear disc & redrilled to 4 1/2 pattern.
(I use Explorer wheels, 15in steel)
Paul
351W 2bbl.
C-4 Auto
3.90 open rear
post #17 of 17 (permalink) Old 05-03-2010, 11:46 AM Thread Starter
tbirdtess's Avatar
Right on, Split
Hi
I strung the car yesterday.
Rears were right on at 50-50 split on the adjusters.
The only problem was, With the new tires I had to raise the car up to see any change. I have to redo the front this way now.
need toe out of 1/8in.
351W 2bbl.
C-4 Auto
3.90 open rear
