Cutting Stock Springs - TCCoA Forums
post #1 of 16 (permalink) Old 03-15-2010, 08:38 PM Thread Starter
Raptor22's Avatar
I have a set of Eibach prokit front springs and SC subframe with Tokico shocks for my SC suspension swap however for the rear I only have the shocks and my stock rear springs. I want matching Eibachs but nobody is willing just to sell me a rear set. Im considering cutting my stock springs. What is the best way to go with that? Any tips? Ideas?
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 16 (permalink) Old 03-15-2010, 09:56 PM
cougar_fan's Avatar
Just going off what I have learned from the autocross guys . . . Cutting stock springs (or any springs for that matter) will change the spring rate, and potentially ruin the ride and handling. IMHO, I wouldn't do it. I'd hold off for a rear set somewhere. Like I said, I have never done it. However, I have ridden in a fox body that was cut (approximately 2 coils cut from eibachs) and it was hard as a rock with terrible drivability. Either way it is your car and the best to you . . . just my .02 cents
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/forumdisplay.php?f=95
cougar_fan is offline
post #3 of 16 (permalink) Old 03-15-2010, 10:41 PM Thread Starter
Raptor22's Avatar
Thanks man. I appreciate the input, its just an idea I have been kicking around.
Raptor22 is offline
post #4 of 16 (permalink) Old 03-15-2010, 10:43 PM
There is absolutely nothing wrong when cutting springs (when done right). Yes, the spring rate will go up, but lowering springs have higher spring rates too
post #5 of 16 (permalink) Old 03-15-2010, 11:03 PM
cougar_fan's Avatar
Like I said, I have never done it and haven't done a lot of research. I was just going off what the autocross guys tell me. If the majority here say you're good, then go for it
post #6 of 16 (permalink) Old 03-15-2010, 11:05 PM Thread Starter
Raptor22's Avatar
Now how should I go about doing it? I actually have an extra set of stock rear springs that I am not afraid to cut. And if I screw them up I can always put the others back on or try cutting them too.
Where should I cut? What should I use. Will I need to modify the housing?
Raptor22 is offline
post #7 of 16 (permalink) Old 03-15-2010, 11:06 PM
cougar_fan's Avatar
Can't help you there man. Never done it. Hell, google it Nah, just wait, you'll get a good how to from the guys on here.
post #8 of 16 (permalink) Old 03-15-2010, 11:32 PM
The fronts you cut the bottom of the spring (the part on the perch of the shock, not the flat part that mounts to the body), the rears can be cut from either end.
Only use a cut off wheel to cut the springs and make sure they don't get too hot in the process. Also make sure to cut the springs evenly left to right.
post #9 of 16 (permalink) Old 03-15-2010, 11:41 PM
XR7-4.6 is correct. I cut my springs as a temporary fix as I was dumping a lot of money (for me) into the car on other things and was a little short on funds. One of my front springs was broken so I trimmed a little more off and evened out the other side, I then trimmed the rears the next day after work. Driving it around for a day with some pretty intense rake was funny. What started as a band-aid ended up staying as the ride isn't too bad and stiffened it up a decent amount. The next time my car gets completely tore down (post graduation) I will replace them with proper springs. For the time being, the cut springs have been more than acceptable and have not 're-broken'.
coolhandzep is offline
post #10 of 16 (permalink) Old 03-16-2010, 07:44 AM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
When I changed my driver side front suspension out, my spring was broke, I'm doing the passenger side today and I will even them out.
92 Cougar LS 5.0: Air Silencer delete, Flowmaster Cat-back System, Big 3,Cold Air Intake,
77 BMW 530i(no longer running will come spring)
02 Caravan SE(DD 4 kids)
beamerboy46350 is offline
post #11 of 16 (permalink) Old 03-16-2010, 07:49 AM
when cutting them, start with 1 coil, then do half's.
post #12 of 16 (permalink) Old 03-16-2010, 08:02 AM
Earl's Avatar
It's strange as far as the ride/handling goes...but not nearly as bad as everybody makes it out to be if it's done right...mine has cut springs, they where cut correctly, and it looks great, handles like it's on rails, but rides REALLY rough, and if I hit the gas just right it feels like the front drivers side wheel bounces/hops/leaves the ground for a second, which is weird. But all & all if you want a lowered car and don't have the money for a set of lowering springs, cut away...but be careful, and get them right...not something I would want to try, but have at it
Earl is offline
post #13 of 16 (permalink) Old 03-16-2010, 09:22 AM
cutting springs
count the amount of live coils (not in the perchs)i.e. if there is 10 coils and you
take one off your spring rate will increase 10 percent. use only a cut off wheel as
mentioned above and do it in half coil increments - tire baron
TIRE BARON is offline
post #14 of 16 (permalink) Old 03-16-2010, 07:26 PM Thread Starter
Raptor22's Avatar
Thanks guys.
I am probably going to cut off a single round only as that will lower it sufficiently and still fit in the perch without modification. I appreciate the input. You guys are awesome.
Raptor22 is offline
post #15 of 16 (permalink) Old 03-20-2010, 09:47 PM
CrystalPistol's Avatar
I have a set of cut coils on a '92port, ride is just a little stiffer than stock but if it weren't, it'ld bottom out easier wouldn't it? I really like it, not harsh at all. Also saw no need for more sway bar stiffness, stock is OK.
Here's two links to threads I've participated in on the subject.
http://forums.tccoa.com/showthread.php?t=125480
http://forums.tccoa.com/showthread.php?t=115311
I also have a '95 LX 4.6, low miles, stock shocks and stock springs. Been thinking of cutting the LX coils for a 1 inch or maybe 1-1/2 inch drop? Looking for "how much to cut".
I have another set of sport "JJJJ" springs like on the '92 already cut exactly the same stored away, so may install them instead.
I'll look back soon to see how much would need to come off the stock LX springs (not sport springs).
CrystalPistol is offline
post #16 of 16 (permalink) Old 03-20-2010, 10:25 PM Thread Starter
Raptor22's Avatar
Cool man, thanks. Yeah, see I have a Base Thunderbird not an LX or sport so it makes a difference. I am actually just thinking of getting this set of eibachs" http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
What do you guys think?
Raptor22 is offline
