Strut Rod Bushings - TCCoA Forums
post #1 of 24 (permalink) Old 03-25-2010, 07:36 PM Thread Starter
Captain Cornflake's Avatar
Send a message via AIM to Captain Cornflake Send a message via Skype™ to Captain Cornflake
Strut Rod Bushings
So general consensus around here seems to be only go with Ford for strut rod bushings. Well, going with the part numbers here, the Ford/Motorcraft parts website returns zero results.
Did they quit making them? If so, are there any aftermarket brands that hold up at all?
Captain Cornflake is offline
post #2 of 24 (permalink) Old 03-25-2010, 09:35 PM
I checked Tasca's site scrolling thru the menu, not the part numbers and they're showing them.
post #3 of 24 (permalink) Old 03-25-2010, 09:39 PM
Interestingly, however, RockAuto doesn't list them. All they have are Raybestos and Moog.
post #4 of 24 (permalink) Old 03-26-2010, 02:27 PM
If you are looking for the factory Ford Replacements bushings, then check out Green Sales Company. They have alot of hard to find or discontinued parts in stock and can send them to you. They have them for pretty cheap. You can also check out Silverstate Ford Parts too. Both usually have hard to find parts instock for pretty cheap prices.
Green Sales Company : http://www.greensalescompany.com/
Silverstate Ford Parts : http://www.directfordparts.com/
speedbird8807 is offline
post #5 of 24 (permalink) Old 03-26-2010, 06:04 PM
The Ford tension strut rod bushings are indeed still available from Ford. The only problem is that the kit for the frame side of the tension strut retails for, like, $229.00 PER KIT!!!
However, my local Ford dealer is supposed to be getting me 2 of those kits from another dealer for only $45.00 each!!
post #6 of 24 (permalink) Old 03-26-2010, 10:08 PM Thread Starter
Green Sales had one kit for the frame side left marked down to $130 or so. Checked out Silverstate and was able to get just the bushings, along with the ones for the control arm side for $75 shipped. The bushings on mine aren't even that bad, so I'm hoping I can salvage the sleeves like this guy did. If not, I guess I'll make another order, haha.
post #7 of 24 (permalink) Old 03-27-2010, 11:29 AM
My problem is that I threw away all the original Ford parts when I changed my strut rod bushings last year, so I've had to buy ALL new Ford parts! I didn't realize that I was going to have SO much trouble with the NAPA parts I installed in place of the Ford parts. They are COMPLETE junk! The metal sleeve that installs on the strut rod where it passes through the frame (and which the rubber bushings go over) was mushroomed really bad because it is way too long (I had to cut some of it off, but that still didn't help) and I'm just having problems with my front-end and with the way the car drives that I don't feel I should be having after replacing my ENTIRE front suspension last year (UCA's, LCA's, shocks, springs, inner & outer tie-rods and I used ALL high-quality Moog, TRW and Vogtland parts)! My car feels like it's wandering a bit on the highway and some times I have a bad vibration and I feel like it's the fault of the ill-fitting NAPA parts. My tires were also brand-new at the same time and are high-quality Continentals and not some cheap, no-name brand - besides, I don't think it's a wheel balance problem due to the fact at times there's almost no vibration at all!
Anyway, I bought the individual bushings from Ford for the strut rod where it passes through the LCA, and I had to pay $30 (including shipping) for the four washers that go there too because they were obsolete from Ford and I had to find a dealer that had some in stock still. And, as soon as my Ford dealer calls and tells me he got the kits in for the frame side, I'll pick them up and then install all the new Ford parts. I'm hoping that helps with the problems I'm having (I've had the car aligned 2 times since I installed the front-end parts, so I know I put everything on right)!
post #8 of 24 (permalink) Old 03-28-2010, 03:36 AM
That's because RockAuto doesn't list Ford service parts.
post #9 of 24 (permalink) Old 04-10-2010, 12:50 PM
I recently rebuilt most all of the front end on my '96. I went with the $400+ ford bushings, and I do not regret it. I do, however, regret not cutting the ferrules a little bit, my steering feels a bit "notchy" like its "too tight" or binding and producing too much "feedback". I later read of someone who had similar results who then took it all back apart and cut the ferrules and it resulted in much smoother steering response.
EDIT: I didnt cut them originally because they were the same size as factory originals.
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #10 of 24 (permalink) Old 04-12-2010, 09:16 AM
I wonder if Ford is still producing those parts, or they are just selling out stock(likely). In a few years they will be all gone.
Maybe the poster DLF should fabricate a set.
I don't think it would cost more than $400.
95 4.6L Rusty Survivor!
tbirdguy is offline
post #11 of 24 (permalink) Old 04-12-2010, 09:20 AM
I hate to say it but I used Oreilly's house brand when doing my mark and they fit perfectly and seem to be of good quality. I haven't had any problems with them.
2004 Subaru OBW MT (95k) - "The lesmobile" slow, but capable
1987 Merkur XR4Ti (49k) - fixing electrical issues & getting it running right... then mods
1993 Lincoln Mark VIII (129k) SOLD
wood_e is offline
post #12 of 24 (permalink) Old 04-12-2010, 09:34 AM
It's interesting that you say that about your steering feel because I rebuilt my entire front-end last summer and, ever since that time, have had what I would describe as the exact same sensations from my steering! I have attributed it either to a bad steering rack (which I think is unlikely) or to the ill-fitting NAPA strut-rod bushings I used. I ended-up taking the strut-rods off because I had a washer on backwards on one side (yeah, I know that it probably didn't matter but it bothered me to know I put it back together like that - I'm kinda anal that way!) and I found the metal sleeve was all crushed on the end from tightening the nut against it (the sleeve was made too long). I took them apart, cut the crushed part off the sleeves and then re-assembled them, but it still just never felt right. I'm replacing them with all Ford parts but I'm starting to get a little aggravated with my local Ford dealer because he's supposed to be getting me (2) of the frame-side kits from another dealer (at much less than retail), but it's been almost a month now and he still doesn't have them (even though I gave him my credit card info so I could pre-pay for them)! I'm starting to think he's just jerking me around (the other dealer wouldn't sell them to me at the same discount he'd sell them to another dealer for, so that's why I asked my local dealer to obtain them - he said he'd be happy to)! I may have to just bite the bullet and order them myself.
As far as I know, Ford is still producing them. They are probably charging so much for them now because it costs a lot to have such a limited quantity produced. But, I could be wrong!
post #13 of 24 (permalink) Old 04-12-2010, 09:39 AM
I don't understand why Ford would make those ferrules so that one of them "may" need to be trimmed down in size, but even the factory replacement procedure states the one of them (I forget which one without reading it again) needs to be, I think, about 1/4" shorter than the other one! My original ones did not appear to be cut in any way when I removed them, so why aren't the replacements made exactly the same way?!!
Or, are they?
I'm going to be replacing mine with new Ford parts soon, and I need to know if I need to trim one of the ferrules?!!
post #14 of 24 (permalink) Old 04-12-2010, 11:16 AM
I know they list at $230 and tascafordparts.com lists it at $100:
E9SZ3A187A $229.05 $0.00 $100.78
BSHG & WSHR KIT
so there is a TON of dealer markup in the price. People even got them cheaper. Even if the dealer cost is $60-$70, I bet there is $40-$50 in it Ford. Good for them though. They probably know the story about the part and there is no suitable aftermarket for it. I'm surprised moog or one of the big guys can't copy it correctly though. Its not exactly complex!
tbirdguy is offline
post #15 of 24 (permalink) Old 04-12-2010, 11:18 AM
Or, are they?
Yes, that is very strange. Maybe the replacement parts were tooled a bit too long, and it wasn't worth to modify them. Who knows
tbirdguy is offline
post #16 of 24 (permalink) Old 04-13-2010, 11:03 AM
BSHG & WSHR KIT
Dealer COST on this item, part #E9SZ-3A187-A, is $91.62 (at least as of 2/27/2010 it was)!
post #17 of 24 (permalink) Old 04-19-2010, 05:41 PM
Tbird1997's Avatar
so is www.silverstatefordparts.com still the best and cheapest way to get just the bushings? $29 shipped. mine are shot and i need them bad.
-Patrick
Tbird1997 is offline
post #18 of 24 (permalink) Old 04-20-2010, 03:13 PM
Tbird1997's Avatar
i talked to a guy at napa and they said get them directly from Ford...
-Patrick
post #19 of 24 (permalink) Old 07-05-2010, 06:45 AM
To the top!
Bumping this thread, easier than starting a new one!
I'm in the middle of tearing my front suspension down and will be replacing the strut rod bushings. I bought the Ford kits from Jon and want to know about the ferrules.
dmw_4814 and 96_LX, did you guys have to cut them down and which one, or both?
post #20 of 24 (permalink) Old 07-05-2010, 12:36 PM
Sig Nazi & Gallery Moderator
mrs.tbirdbrain's Avatar
Hey Joe,
I just asked the hubby - he says it's a two-piece ferrule and you don't need to cut them down. After multiple installations of non-ford parts, all of those cars he worked on were changed back to ford parts without any part modification and with no issues
TBIRDBRAIN - PRESTON
YOU WILL NEVER BE FORGOTTEN
4/22/63 - 4/23/14
RIP JOEL BENDER
07/30/1979 - 03/26/2006
mrs.tbirdbrain is offline
post #21 of 24 (permalink) Old 07-05-2010, 06:58 PM
Thanks Michelle!
After I pulled the strut rod out today, the ferrules were frozen on the rod. They looked to be the same size as the new ones. I was working on getting the bushing off the shock end of the rod when i noticed the ferrules on the other end had loosened up! See what a hammer can do for you. Looking at them on the other end I could see the smaller sleeve needs to be pushed in quite a bit more. So, yes trimming doesn't look to be necessary.
post #22 of 24 (permalink) Old 07-06-2010, 01:14 AM
Joe,
I have not yet installed my new strut-rod bushings; in fact, I am going to the dealer later today to pick-up my last frame-side set (I already have the 1st frame-side set and both lower control arm side bushings/washers). I was going to tear the front end apart and change these parts today after I went to the dealer, but I live in an apartment and have to go over my father's house to work on my car and, unfortunately, he has to go somewhere today. So, I will be unable to install them until this weekend, at the earliest (it would've been too hot to work outside today, anyway - it's supposed to be about 92 here in Cleveland)!
Anyway, I will NOT be cutting either of the ferrules; the factory replacement procedure states one of the ferrules has to be at least 1/4 - 1/3" (I think) shorter than the other and looking at the one frame-side kit I already have, one of the ferrules is clearly already shorter than the other.
If you don't mind my asking, how much did you pay for your kits? I got one from a dealer in Nebraska and I paid, including shipping, about $52 for it. The second kit I had a local dealer get for me from another dealer, since that other dealer refused to sell it to me for the same cost he'd sell it to another Ford dealer for. I will be paying about $60 for that kit, also including the shipping charges. I bought them this way because I sure as hell wasn't going to pay about $230 for each kit (that's about 20% of the total I paid for the whole car - just for EACH kit!!), and I knew that a dealer who'd had this kit in stock for a good number of years would be willing to deal on it!
post #23 of 24 (permalink) Old 07-06-2010, 01:26 AM
The strut-rod frame-side bushing kits you get from NAPA are not ANYTHING like the Ford factory parts at all!! They are COMPLETE JUNK!! That is what I stupidly put on my car last year and I have had nothing but trouble because of them (I believe)!! First of all, they do not come with two metal ferrules; they come with ONE metal sleeve that is WAY too long; when you try and tighten the nut on the end of the strut-rod to something approaching the proper torque, the sleeve gets crushed and the end of it "mushrooms" out. This results in strut-rod bushings that do NOT perform their intended function at all, and I now have a slight wandering feel in the steering at highway speeds, a vibration in the car at highway speeds and a slight feel as if the steering is "binding" or "sticking" when I'm driving on the highway. I believe this is all caused by the cheap, ill-fitting NAPA parts; my car just does NOT feel right even though I COMPLETELY rebuilt my front-end at the same time last year using ALL high-quality MOOG parts (as well as, at the same time, brand-new Continental ContiProContact tires)!
I tried to contact NAPA via their website last year to inform them of the problem with these kits and they just TOTALLY ignored me!
Man, I just can NOT wait to get my Ford strut-rod bushings installed!!!!
post #24 of 24 (permalink) Old 07-06-2010, 01:31 AM
Just out of curiosity, where did you get a $29 price for strut-rod bushings at this site? I typed in the part number for the kit, E9SZ-3A187-A, and the search returned zero results. I also looked through the part listings on the left side and found no listing for any kind of strut-rod parts at all.
