suspension parts swap -- GO-> - TCCoA Forums
post #1 of 6 (permalink) Old 03-28-2010, 04:00 PM Thread Starter
tbirdtess's Avatar
Hello
Going to swap some parts to upgrade.
First: LF spindle swap to 94
Pony hub & rotor
Spring change also on my Koni's
Well I swapped the spindle, Pony hub + rotor &
New calipers & brakes.
Hey I learned the right way to install front calipers. lol
Now I need some parts:
New crown nut(tie rod) & sway bar end link.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 6 (permalink) Old 03-28-2010, 11:42 PM
CrystalPistol's Avatar
What happened to the crown nut?
CrystalPistol is offline
post #3 of 6 (permalink) Old 03-29-2010, 05:12 PM Thread Starter
tbirdtess's Avatar
nut
Hello
well it wouldn't come off, then it fell off. threads are messed up.
351W 2bbl.
C-4 Auto
3.90 open rear
post #4 of 6 (permalink) Old 03-29-2010, 08:45 PM
Originally Posted by tbirdtess View Post
Hello
Uhh, well if the threads on the nut are messed-up, aren't the threads on the stud that it goes on going to be messed-up too? You may just have to buy a new outer tie rod. They aren't all that expensive - about $30-$40 bucks.
post #5 of 6 (permalink) Old 03-29-2010, 09:36 PM
Hello
Oh ... I see ... well, actually ... I don't see.
In fact, never seen all that on same nut?
It didn't mess up the threads on the tie rod end ball joint stud too?
post #6 of 6 (permalink) Old 03-29-2010, 10:27 PM Thread Starter
tbirdtess's Avatar
spin out!
Hello
Must of happened when I spun out last season.
Lost RR tire, Was passed by this tire. lol
Was towed back. Nut was pinned & joint was still snug to spindle.
New tierod only about $20.00us
next step. But still need new sway bar end links. 94up
351W 2bbl.
C-4 Auto
3.90 open rear
