koni's front inserts - TCCoA Forums
post #1 of 7 (permalink) Old 04-10-2010, 02:11 AM Thread Starter
thunderclaw's Avatar
does any one know how to install koni's front inserts? i read a couple of posts, but the weren't to descriptive. pics would be greatly appreciated. i ordered the koni's and i'm nervous about installation, they keep saying is pretty straight forward but they talk about cutting a pressurized strut open. i don't think of myself as a begginer 'cause i've done engine and tranny swaps but it does make me wonder if i have everything (tools) i need to tackle this one. please help!
thunderclaw is offline
post #2 of 7 (permalink) Old 04-10-2010, 02:12 PM
tbirdtess's Avatar
Koni's
Hello
Well you drill A small hole in the bottom of the shock.
Cut top off. I used a high speed cut off tool.
Empty shock.
redrill bottom hole to 3/8 I think.
Debur all.
insert the Insert, put bolt in bottom with lock-tite.
rubber upper sleeve
reinstall spring assembly.
put back on car.
I used a set of Bad shocks when I did it.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 7 (permalink) Old 04-10-2010, 02:23 PM
dDUBb's Avatar
The trick is to cover your drill / the bottom of the shock while you are drilling a small hole .. when it breaks through it will spray even if you think the shock is bad. I cut the top right below the top weld with a hack saw around the outer tube.
dDUBb is offline
post #4 of 7 (permalink) Old 04-10-2010, 02:24 PM
Earl's Avatar
yeah mine are in a set of KYB housings so apperantly those can be used as well as stock shocks
Earl is offline
post #5 of 7 (permalink) Old 04-10-2010, 02:47 PM
DLF
DLF's Avatar
I used a new set of cheap Monroe's as donors.
My Web Site
DLF is offline
post #6 of 7 (permalink) Old 04-10-2010, 04:53 PM
Black_Cat's Avatar
It's easy enough but you need a good clamp and you can use a hacksaw to cut the shock housing open like I did....it's tedious but pretty straight forward.
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #7 of 7 (permalink) Old 04-11-2010, 09:37 PM Thread Starter
thanks for posting. really helped! all i have todo is wait case i just found out my koni's are on backorder. i'm also waiting on the vogtland springs 3/4" drop, wonder if they are a good combo with my shocks. i bought sport springs before when i pulled my bird out of the dealer(back in '95). i guess they were early prototypes because they made my car look good, but it felt like ridding a floorjack!
i've heard very good things about the vogtland's. looking forward to try 'em. any thoughts on this?
