Need rear suspension torque specifications - TCCoA Forums
post #1 of 8 (permalink) Old 04-21-2010, 12:48 AM Thread Starter
Please help. I need the torque specs for the rear suspension of my 90 Thunderbird LX V6.
ecks.autofan is offline
post #2 of 8 (permalink) Old 04-21-2010, 02:04 AM
Nitemare's Avatar
Which part? There's a lot to the rear suspension, with a lot of torque specs.
Needs more stall.
Nitemare is offline
post #3 of 8 (permalink) Old 04-21-2010, 02:59 AM
dDUBb's Avatar
Tighten the big nuts to 100 ft lbs, and the small ones to 50 ft lbs.
dDUBb is offline
post #4 of 8 (permalink) Old 04-21-2010, 03:17 AM
While on the subject!
When torquing the rear knuckles to the rear control arms, does the weight of the car need to be on the suspension like it does when torquing the front suspension? I haven't heard mention of it before so I figured I'd ask!
post #5 of 8 (permalink) Old 04-21-2010, 05:53 AM
A good rule of thumb is any time you tighten a nut/bolt that passes through a suspension pivot point, the weight of the car needs to be on the pivot point (and preferably with both sides with the weight of the car on them so both corners are at the same height/load).
I try to snug it up and then bounce on the suspension a couple of times to settle it out, and then torque the nut/bolt to spec.
But that is just the way I do it and it may or may not be the best way.
69 F100 LWB w/460 Engine
post #6 of 8 (permalink) Old 04-21-2010, 07:26 AM
DLF
DLF's Avatar
NOT very good advice!
Yes.
My Web Site
DLF is offline
post #7 of 8 (permalink) Old 04-21-2010, 01:01 PM
dDUBb's Avatar
Yes.
The question was not very specific. But for most of those bolts, those torqe specs are within range.
dDUBb is offline
post #8 of 8 (permalink) Old 04-22-2010, 12:07 PM Thread Starter
Thanks DLF for the complete torque specs.
