how low? - TCCoA Forums
post #1 of 25 (permalink) Old 04-24-2010, 10:32 PM Thread Starter
thunderclaw's Avatar
Question how low?
i'm getting vogtland spring for my ride. i'm having a hard time deciding how to go 3/4" or 1.6" i wanna get rid of that hedious fendewell gap, but i have a ground effects kit i salvage from my other tbird i wrecked and dont want to be scrapping all over the place. any ideas?
thunderclaw is offline
post #2 of 25 (permalink) Old 04-25-2010, 11:37 AM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
1.6 is not enough afaic.
-John
MAMN-12 Fringe Member
94MN1246 is offline
post #3 of 25 (permalink) Old 04-25-2010, 12:18 PM
Tbird1997's Avatar
i have a 1.5in drop on eibachs and if i didnt have the gfx i would prob want a 2in drop.
-Patrick
Tbird1997 is offline
post #4 of 25 (permalink) Old 04-25-2010, 01:02 PM
crash00527's Avatar
Send a message via AIM to crash00527
Vogtland 1.6.. BEST choice
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #5 of 25 (permalink) Old 04-25-2010, 05:16 PM
CrystalPistol's Avatar
There will be times when you'll think any lowering is too much, but 1 to 1.5 inches really makes a noticeable change in that gap, and keep tires at least as tall as a 225/60-16 or 215/70-15 on it. Wider is OK, but no shorter.
CrystalPistol is offline
post #6 of 25 (permalink) Old 04-26-2010, 03:16 PM
I'd definitely go with the 1.6", .75" isn't nearly enough.
skootboy is offline
post #7 of 25 (permalink) Old 04-26-2010, 03:21 PM
crash00527's Avatar
what are you talking about???? i have the 1.6 drop with 245/45/18's and have ZERO problems and car look great!! and im pretty conservative when doing mods like that.
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #8 of 25 (permalink) Old 04-26-2010, 03:39 PM
Tbird1997's Avatar
i think you miss read. he said atleast stock tires, he means you can go taller and wider than stock But no shorter.
-Patrick
post #9 of 25 (permalink) Old 04-26-2010, 11:23 PM Thread Starter
even w/ ground effects? has anybody had problems gettin a dropped w/ ground effects into a aligment machine?
post #10 of 25 (permalink) Old 04-27-2010, 09:29 AM
MAMN12 Posse Member
JeffTBird93's Avatar
When I had the Eibach's on, I had about a .75-1" front fender-tire gap. With the SC kit I still had no issues with getting it aligned. The only problem's I had with clearance was the exhaust dragging on speedbumps.
~Jeff
*signed off
JeffTBird93 is offline
post #11 of 25 (permalink) Old 04-27-2010, 11:27 AM
crash00527's Avatar
I have no issues with mine as of yet. I've driven over speedbumps hit some bad roads... The key is to either avoid them or just go over them slowly that's all.
I'm nervous when I change my exhaust if I'll have any issues.
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #12 of 25 (permalink) Old 04-27-2010, 11:47 AM
Same here with my setup 1.5 drop and true duals Have yet to drag anything my exhaust guy done her right
post #13 of 25 (permalink) Old 04-27-2010, 01:38 PM
Smile
That's right.
The poster opening the thread wanted to minimize the gap, not increase it. He wanted to drop the car in part to do it ... and he was concerned about ground clearance.
http://www.1010tires.com/TireSizeCal...?action=submit
225/60-16 is nominally 26.62" diameter
215/70-15 is nominally 26.85" diameter
245/45-18 is nominally 26.68" diameter
Your 245/45-18s are "OK" it seems.
Later .......
post #14 of 25 (permalink) Old 04-27-2010, 02:34 PM
silverbird97's Avatar
Thanks for the site. Thats quite helpful.
97 T-bird Silver 4.6
If it aint one thing its another.
silverbird97 is offline
post #15 of 25 (permalink) Old 04-27-2010, 08:01 PM
You're welcomed, I use it often. Used to have to calculate it long hand.
post #16 of 25 (permalink) Old 04-28-2010, 12:09 AM
Maic's Avatar
True Dual Helps
True Dual Helps
Just don't lower it and go with some 20" or 22" rims. Always gotta sacrifice, thats how it is.
-Maic
Maic.
Maic is offline
post #17 of 25 (permalink) Old 04-28-2010, 08:51 AM
MAMN12 Posse Member
How do true duals help? I have true duals.
~Jeff
*signed off
post #18 of 25 (permalink) Old 04-28-2010, 01:55 PM
Maic's Avatar
If you still drag on speedbumps then i quess your have a mid-mount Muffler !
-Maic
Maic.
Maic is offline
post #19 of 25 (permalink) Old 04-28-2010, 03:40 PM
MAMN12 Posse Member
I do, but that's not what I have problems with. It's where I have it clamped together.
~Jeff
*signed off
post #20 of 25 (permalink) Old 04-28-2010, 07:03 PM
94MN1246's Avatar
the lowest point on my bird is not the exhaust... how the hell are you guys scraping?
John
94MN1246 is offline
post #21 of 25 (permalink) Old 04-28-2010, 08:42 PM
crash00527's Avatar
mine isnt that low either. looks low but isnt
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #22 of 25 (permalink) Old 06-01-2010, 05:52 AM
MAMN12 Posse Member
John
Your car really doesn't sit that low...
~Jeff
*signed off
post #23 of 25 (permalink) Old 06-01-2010, 09:04 AM
95xbird's Avatar
I got the 1.6 Vogtland on my car with a body kit and 245/45ZR17's which is 25.7 in diameter. And I have a mid mount. And I DONT SCRAP AT ALL! I guess its how you approach certain things. Oh and go with the 1.6V's I love them!
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #24 of 25 (permalink) Old 06-06-2010, 02:06 AM
I have 1,6 Vogtland, Koni adjustable shocks and Adco 1 3/8" rear sway bar . Wheel is the original 215/70x15. New wheel will be 235/55x17. They are only 7 mm (~1/4") bigger than the original. Hope to have the new wheel mounted next weekend.
The roads around here are not that good, but it functions perfect with no problems. I have the Koni at the hard in front and soft in rear.
This winter everything in the rear driveline/suspension was up graded and next winter will be the front.
Around 15 - 1.6 drop will take care of your problem
Berth is offline
post #25 of 25 (permalink) Old 06-06-2010, 02:07 AM
Sorry it should have been 1.5 - 1.6 drop
Berth is offline
