Clunk only on the rebound when braking - TCCoA Forums
post #1 of 2 (permalink) Old 05-19-2010, 10:53 AM Thread Starter
Drivers side only. There is a clunk in the suspension only after moderate-hard braking when the car recoils back up.
The suspension is quiet on bumps and on the highway.
I can re-create it at will. Just have to jump on the brakes so that it nose dives a little, and let off. Its when I let off the brakes that it clunks. It sounds almost like its up high, and you can feel it pop in the brake pedal or so it seems.
The car has 53K miles on it. The upper control arm and ball joint have been replaced. The sway links are suspect due to the rubber boots being torn. I have stuck my head under there, cant see anything else wrong. I've put a socket on the frame side strut mount, and the big washer turns when the car is on the ground but tight when up in the air. I tightened the three bolts for the strut mount.
Same thing.......any ideas???
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #2 of 2 (permalink) Old 05-19-2010, 01:57 PM
DSM
sway bar end links or sway bar bushings.
DSM is offline
