Proper UCA Installation - TCCoA Forums
post #1 of 24 (permalink) Old 05-21-2010, 03:54 AM Thread Starter
d00mbuggy's Avatar
I read a post a while ago about this, and I can't find it. I remember something about making sure the UCA is in the fully upright, full load position before torqueing it to the the proper specs, not sure what the torque is either. Can anyone help with a link to this post or refresh my memory, as I am installing new UCA's and end links while installing new lowering springs(Eibach Pro kit). I know that we encourage reading older posts to find this info, and i did, but couldn't find it.
Thanks!
PS: If this isn't really necessary, then I apologize, Just wanna do it right.
'97 4.6l. Air silencer gone, PI Intake, Eibach Springs, Clear Corners, Silver Saleen Speedstar Wheels,FR500 Steering Wheel. I'm happy.
d00mbuggy is offline
post #2 of 24 (permalink) Old 05-22-2010, 01:17 AM Thread Starter
d00mbuggy's Avatar
Wow, 43 looks, and no replies, I'm a little surprised. oh well.
post #3 of 24 (permalink) Old 05-22-2010, 01:32 AM
dDUBb's Avatar
For some reason around 50 or 60 ft lbs comes to mind for the UCA nuts. Need to be tightened with the suspension loaded. 18mm nuts.
dDUBb is offline
post #4 of 24 (permalink) Old 05-22-2010, 10:08 AM
tbirdtess's Avatar
uppers?
Hello
I have removed & changed my arms on my car many times.
I have never properly torqued them.
But my car is not a street car, I don't do the normal stuff
But I can say is is best to tighten when the car is under full weight.
I generally jack that corner up when tightening(off the stand)
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #5 of 24 (permalink) Old 05-22-2010, 01:54 PM
dDUBb's Avatar
Originally Posted by tbirdtess View Post
Hello
The proper torqe spec for the UCA nuts is 65-88 FT lbs .. I was close with 60.
The only time I use a torque wrench is when I am doing suspension .. or building an engine.
dDUBb is offline
post #6 of 24 (permalink) Old 05-22-2010, 02:04 PM
DavyZ's Avatar
Originally Posted by d00mbuggy View Post
I read a post a while ago about this, and I can't find it. I remember something about making sure the UCA is in the fully upright, full load position before torqueing it to the the proper specs...
So does anyone know what the consequences are of not doing this? The reason I ask is that I recently replaced mine, but I cannot remember if they were in the "full and upright position" when I torqued the nuts & bolts. Cripes, I hear noises from them (like ungreased rubber bushings or something) when going up & down the driveway and over bumps slowly. Hmmm, I may have to re-tighten them correctly when I install my Eibachs and LCAs this next week...
Eh, live & learn...
Davy
DavyZ is offline
post #7 of 24 (permalink) Old 05-22-2010, 02:49 PM
dDUBb's Avatar
Eh, live & learn...
Davy
Sounds like your bushings are binding up. This can also lead to premature failure.
dDUBb is offline
post #8 of 24 (permalink) Old 05-22-2010, 02:58 PM
Best way to do this is to jack up the car from the LCA until the weight comes off your jack stand(s)... then torque them down.
post #9 of 24 (permalink) Old 05-22-2010, 08:55 PM Thread Starter
d00mbuggy's Avatar
Right on!
Cool, thanks you guys! That's about what I figured, but I wanted to be sure before I install my new ones along with the swaybar end-links (all MOOG). They came with self tapping grease fittings and the ball joint is already greased, so do I have to add more grease after installling them?
post #10 of 24 (permalink) Old 05-22-2010, 08:59 PM
I don't think you have to add grease... but it's one of those, "why not?"
post #11 of 24 (permalink) Old 05-22-2010, 09:40 PM Thread Starter
d00mbuggy's Avatar
Grease
I hear ya. I don't have my own grease gun, but I can just take it in for an oil change and have it done then. I know, you're thinking "he's gonna install new suspesion parts himself, but can't change the oil himself?". Of course I can, but If I'm gonna get the lube job, might as well have them change the oil while its there.
post #12 of 24 (permalink) Old 05-22-2010, 11:21 PM
dDUBb's Avatar
The Moog are Pre-greased ... from my experience, if you add more grease, it will be too much and make a mess.
dDUBb is offline
post #13 of 24 (permalink) Old 05-23-2010, 04:25 AM Thread Starter
d00mbuggy's Avatar
Thanks for the heads up! They did look pretty good to go. From what i've read, MOOG are as good as you can get aside from Factory, and as I'm just replacing old worn parts while I'm in there, not lookin to road race it, just lowering it with the Eibach Pro Kit. I've been through this before, when I lowered my other Bird. Installed the springs only, with worn ball joints, and end links. Had to pull it all apart later to finish the job right. Now, on my new Bird, i saw the worn ball joints, worn end links, so I bought all new parts, to replace while installing the springs.
Why not take care of it now while it's gonna be all apart anyway.
post #14 of 24 (permalink) Old 05-23-2010, 10:26 PM
CrystalPistol's Avatar
Thanks!
I instrall bolts / nuts / and tabs, then set her down on her wheels, then torque to spec.
CrystalPistol is offline
post #15 of 24 (permalink) Old 05-26-2010, 07:05 PM Thread Starter
d00mbuggy's Avatar
Eibach Springs
I got it done. UCA's installed properly, torqued with full weight on them, Eibach Springs installed. A pain in the ass job, 2 days work by myself, but well worth the money I saved compared to having a shop do it. A word to the wise, be very careful doing this on an inclined driveway!(Actually I don't recommend it unless you really chock the front tires). I've done this before on another car no problem, but this time I almost had the car roll back off the jack stand with the rear wheel off. You're fine as long as the other rear tire is on the ground, I jacked it up too high and raised both tires temporarily, causing it to start creeping back. Literally had to hold the jack, put a wrench under it's wheel to stop the rolling. Luckily I was able to throw in a 2nd jack stand(on the right) in not the best possible place obviously, also put the wheel under the frame just in case, and chocked the front tires with my old UCA's, finally got the jack out from under and fixed the situation. Pretty scary as you can see in the pic, so live & learn. Anyway, after a big 'PHEW' I finished the job, which was very satisfying, got it done, looks great!
Thanks again for all the info!
post #16 of 24 (permalink) Old 05-27-2010, 02:44 AM
your lucky you didn't hurt yourself next time go to autozone and buy a $6 set of plastic wedge wheel chocks. Now hammer that body seam back. The first jack stand (left) was in a good location but the car should have been supported on both sides not just one. Also it would have given more support turned 90 degrees.
post #17 of 24 (permalink) Old 05-27-2010, 07:32 AM
Earl's Avatar
good info here so next time i do this job i don't make the mistakes i made last time on the front end, specifically, torqueing the uca bolts down with the car off the ground
Earl is offline
post #18 of 24 (permalink) Old 05-27-2010, 10:06 AM
dDUBb's Avatar
LOL, cant say I havent done that. Its a learning experience.
Your car does look very nice by the way.
dDUBb is offline
post #19 of 24 (permalink) Old 05-27-2010, 01:02 PM
The consequences of not tightening the suspension bolts at joints with the suspension loaded (car weight on the wheels) is suspension bushing wind-up. The bushings are bonded such that they can't rotate since they are molded to the arms. You preload them when the bolts are torqued with the arms in the wrong position. You will affect your ride height and assuming you torqued the bolts with the arms hanging down, they will act like little "extra" springs and cause your suspension to be very "floaty"over any road imperfections.
Duffy Floyd is offline
post #20 of 24 (permalink) Old 05-27-2010, 01:16 PM
Earl's Avatar
so if you suspect that your uca bolts have been improperly tightened is it ok to loosen them with the car sitting level on the wheels and then tighten them back down? will this fix any binding that may be present?
Earl is offline
post #21 of 24 (permalink) Old 05-27-2010, 01:27 PM
Loosen the bolts with the weight of the car on the wheels....bounce the car a few times to settle it..re-tighten the bolts to spec. For the other pivot bolts under the car.....do the same process on the alignment rack when you are getting the alignment you should have after doing suspension work.
post #22 of 24 (permalink) Old 05-27-2010, 11:17 PM Thread Starter
d00mbuggy's Avatar
Thanks, Chris Murder, I will always use wheel chocks from now on. SCTBird1994, thanks for the compliment! Now the final step is wheel alignment, even though it rides pretty straight, I know it's the right thing to do of course. I'd like to see them try to find something to get me to replace after this.
post #23 of 24 (permalink) Old 05-28-2010, 09:32 AM
Set the parking brake firmly too. Seriously, always keep a jack as backup. In addition to jackstands, its good to have a floor jack at least on the side you are working on. I usually double up with a floor jack on one side and the tire jack on the other. Or you can snug a floor jack under the front crossmember. This makes it easy to unjack the car too. Two pieces of metal are better than one.
tbirdguy is offline
post #24 of 24 (permalink) Old 05-28-2010, 07:09 PM Thread Starter
d00mbuggy's Avatar
Yeah, normally I do all that, with the floor jack as backup, but I was using it to raise and lower the rear suspension to disconnect it all. Sure, the E-brake on works fine if at least one rear tire is on the ground, but that was the problem,I jacked the car up so high and set the jack stand to that height, that when I lowered it onto the jack stand it shifted the weight to a more centered place on the frame, causing both rear tires to come off the ground, rendering the E-brake useless at that point. Hence, without front wheel chocks, the car rolled backwards. luckily remedied the situation.
