Replacement lower shock mounting bolt - TCCoA Forums
post #1 of 5 (permalink) Old 05-25-2010, 05:12 AM Thread Starter
Hello,
I tried to get my lower shock mounting bolt out, and have failed thus far. I will probably have to cut it out and I am wondering what it can be replaced with? Is there a specific ford part #, or can I just use a similar bolt off the shelf?
What about that unique locking washer on there? can it be replaced without that?
Dan
ddidier is offline
post #2 of 5 (permalink) Old 05-25-2010, 06:21 AM
If you hop on rockauto, look for Monroe part number AK68.
post #3 of 5 (permalink) Old 05-25-2010, 08:18 AM Thread Starter
Brandon,
Thanks! Is there a similar part number for the upper ball joint / spindle bolt?
ddidier is offline
post #4 of 5 (permalink) Old 05-25-2010, 08:20 AM Thread Starter
I also found this:
http://www.amazon.com/Monroe-AK68-Sh...tive&carId=009
which ships for free with Prime, which I have. It looks like this is a pair, but I don't think so based on the part # of the part and other listings.
ddidier is offline
post #5 of 5 (permalink) Old 05-25-2010, 11:11 AM
Rockauto does not appear to sell the upper control arm to spindle bolt/nut separately, however it is included with new Motorcraft upper control arms. Check out tascaparts.com for a better price on the OEM units.
The Amazon.com listing looks like just one bolt. You should be able to get them both off rockauto shipped for about twenty bucks with the 5% discount code (search for the thread).
