More noises with suspension... - TCCoA Forums
post #1 of 37 (permalink) Old 06-06-2010, 01:19 PM Thread Starter
'94bird's Avatar
so I have been battling with suspension issues since I bought this car a year and a half ago. Now every once in a while it makes a sort of popping noise when going over bumps and when I turn the wheel I hear a creaking noise. I have checked the balljoints myself by trying to pull and pry on the wheels while jacked up, but I get no movement. Maybe I am doing it wrong????
1994 Ford Thunderbird 4.6 SOHC........Air silencer delete, muffler delete (LOL), and smoked tails......SOLD!
Current: 1987 Lincoln Mark VII LSC 5.0 HO 3.27 gears
'94bird is offline
post #2 of 37 (permalink) Old 06-06-2010, 01:50 PM
Sway bar endlinks are also very common culprits for such noises. There's no real way to check them while they're on the car that I know of. About $45/ea. from Ford.
post #3 of 37 (permalink) Old 06-06-2010, 06:19 PM
Noises
My 1995 had TONS of noises coming from all over the place (suspension wise) and I systematically changed everything to quiet it down. Upper/lower ball joints, control arm bushings, sway bar end-links, tie-rod ends, you name it.
The last 2 noises I had to deal with were the following:
One of the new rear sway bar end links I put in the end got bend on a stump or something, and the rubber bushing broke and fell out, so I had to replace it again.
The passenger front upper control arm assembly (you can't get just the ball joint, you have to change the whole UCA/ball joint as a unit) that I got from Napa was just bad out of the gate and started squeeking right away after I had replaced both driver & passenger sides. I changed it under warranty and fixed that noise.
Final verdict: rides like a new car!
post #4 of 37 (permalink) Old 07-21-2010, 07:49 PM Thread Starter
'94bird's Avatar
Thats where the nose is coming from in the rear....... Not half as bad as the front, but nonetheless figured out.
Well the popping is getting worse, it happens mainly when I turn the wheel (to the right only) - I hear a pop, and after that the wheel kind of sticks to the right and I have to jerk it to the left to get it to straighten out.
And, of course, a new problem has developed. Whenever I use the brakes, and the front end of the car kind of dips to the ground, there is a very loud creaking noise coming from the front end, this same noise also happens when I turn the wheel at slower speeds (turning it either way.. Maybe the springs???)
This is my dd, so I don't just wanna go replacing parts on a whim,,, It would be nice to get some idea on what's going on in the front, or maybe this has happened to somebody? (i'm sure it has lol) I will be putting new brake pads on this weekend, so further inspection will be done then.
'94bird is offline
post #5 of 37 (permalink) Old 07-21-2010, 09:37 PM
Sounds like lower ball joints to me. How many miles, and were they ever replaced before? Lower ball joint failure is not something you want to risk.
post #6 of 37 (permalink) Old 07-22-2010, 12:07 AM
sounds lie strut rod bushings to me... have you had anyone turn the wheel while you look?
Forgive me When i sound like i have A.D.D.
frst4.6 is offline
post #7 of 37 (permalink) Old 07-22-2010, 09:24 AM Thread Starter
'94bird's Avatar
as far as i know they have never been replaced i wouldnt know how to check..... the car has prob around 175k on it ( odometer dosent work)
how would i check the lowers? would that cause the creaking and popping noise?
'94bird is offline
post #8 of 37 (permalink) Old 07-22-2010, 09:46 AM
The lower ball joints failed at about 160k on my mom's 93 many years back, the precursory indications being creaking sounds on turns and over bumps. To check them, raise the front of the car and set it on jack stands. Then jack up the car at the lower control arm just enough to get the weight off the one side's jack stand. Then have someone grab the tire and rock it back and forth while you watch for movement in any of the suspension components. If you see the lower ball joint moving, it's shot. Likewise for the upper ball joint.
http://forums.tccoa.com/showthread.php?t=98597 is what you don't want to happen.
post #9 of 37 (permalink) Old 07-22-2010, 04:39 PM Thread Starter
'94bird's Avatar
I've tried that a few times, actually, over the course of me having the car, and I try moving the tire and can't get it to budge an 1/8th of an inch.
'94bird is offline
post #10 of 37 (permalink) Old 07-24-2010, 11:58 AM Thread Starter
'94bird's Avatar
I think I got this probllem figured out,,,,,, I just replaced my front brakes, and while doing the passenger side I noticed that the sway bar endlink had seperated at the top. I'm not sure what would cause this unless I got the wrong part sent to me a year ago when I did them last. Would this cause my problems? Here are some pics of what I found
'94bird is offline
post #11 of 37 (permalink) Old 07-24-2010, 12:29 PM
That could cause some strange handling characteristics, but look at your lower ball joint in the first picture, how the rubber boot is all shredded. The ball joint is shot. Also, if the rubber boot is broken or cracked on the top ball joints, you'll need new UCAs as well.
post #12 of 37 (permalink) Old 07-24-2010, 01:28 PM Thread Starter
'94bird's Avatar
I know, I noticed that as well. I found a shop that will do it for $283, which I don't think is too bad. The boots on my UCA's aren't torn, but the ones for my tie rods are.
'94bird is offline
post #13 of 37 (permalink) Old 07-24-2010, 02:54 PM
You should find out what brand of parts your shop will use. The only acceptable replacements are Moog and Motorcraft (TRW).
post #14 of 37 (permalink) Old 07-24-2010, 05:13 PM
I just remedied terrible front end noise today by replacing the upper and lower control arms (moog), and sway bar end links (TRW). They were replacements for OE brand parts that had been in for ~9 months, that stuff is absolute garbage. I know it's been said PLENTY of times on here, just trying to reiterate for anybody considering using this stuff.
Damon
skootboy is offline
post #15 of 37 (permalink) Old 07-24-2010, 08:28 PM Thread Starter
'94bird's Avatar
Thanks for that info - I was unaware. I did put new Moog endlinks in and will definitly buy the LCA's when I have the cash. Until then, I think the safe choice would be to park the bird for now, as I have a 60 mile (one way) commute everyday and having bad ball joints and driving 80 mph down the interstate dosen't seem like a smart idea.
'94bird is offline
post #16 of 37 (permalink) Old 07-25-2010, 10:40 AM
Only if you're suicidal or homicidal.
When it breaks, it will bend your fender, and dig into the pavement.
There's a post somewhere here where someone recently took out a highway divider when one broke... I won't ride that ride, lol.
Please get them fixed before you drive it.
Otherwise, best case, you'll be changing them out in a parking lot. It's really hard to get a jack under the car when it's sitting on the LCA.
Grog6 is online now
post #17 of 37 (permalink) Old 07-25-2010, 11:52 AM Thread Starter
'94bird's Avatar
Although the popping and clunking stopped, the squeaking still remains, but It's parked, for now. Gonna DD my truck for a while, there's a plus to driving that gas guzzler over the bird though............... My truck has A/C
'94bird is offline
post #18 of 37 (permalink) Old 07-31-2010, 01:06 PM Thread Starter
'94bird's Avatar
Took the car to the shop today to see what their diagnosis would be. Inner tie rod on the drivers side. After I replaced very broken passengers side sway bar endlink, most of the noises stopped. I still heard a little noise (haven't replaced the rear endlinks yet) out of the rear, but the front had stopped. They said my balljoints and other bushings checked out just fine. Gonna replace the inner tie rod myself, as well as the rear endlinks, then get a 4 wheel alignment done.
I have never replaced tie rod ends before, and hope the job isn't too bad.
'94bird is offline
post #19 of 37 (permalink) Old 08-01-2010, 12:21 AM
1996Project-bird's Avatar
I had a similar noise from the rear, turns out the bushings on my rear shocks were shot. I replaced them and havent had a problem since. And the inners are not bad at all. just have a big adjustable wrench and you will be fine.
1996Project-bird is offline
post #20 of 37 (permalink) Old 08-29-2010, 08:25 PM
Mgino96tbird46's Avatar
I took a look at my front suspension today. I have similar symptoms as the OP. When driving, I have a creaking noise coming from the front, passenger side. I cut the wheel and took pictures. This is what I found.
Passenger side
passenger side, looking down slightly.
Driver's side
Mgino96tbird46 is offline
post #21 of 37 (permalink) Old 08-30-2010, 08:37 AM
what about your uppers? Everything looks good to me cept maybe that lower boot pass. side is giving out
jjTbirdjj is offline
post #22 of 37 (permalink) Old 08-30-2010, 08:43 AM
uppers are all intact. They were replaced within the past 3 years.
post #23 of 37 (permalink) Old 08-30-2010, 09:57 PM
I'd replace the lowers for sure; they're both the same age.
Since they're teflon lined, groaning means they're about to pop.
YMMV.
Grog6 is online now
post #24 of 37 (permalink) Old 08-30-2010, 10:01 PM
Passenger side lower? Or both passenger and driver side? I don't get any noises from the driver's side, and it looks fine.
post #25 of 37 (permalink) Old 08-30-2010, 11:03 PM
Does Moog make a good replacement? I take clover leaves aggressively sometimes.
post #26 of 37 (permalink) Old 08-30-2010, 11:20 PM
Suggestion: Find a vendor that shows the 1989 Thunderbird SuperCoupe as a different stock # for the lower control arm, and buy that one.
Firmer bushings is the difference from Ford.
RalphP is offline
post #27 of 37 (permalink) Old 08-30-2010, 11:49 PM
What if I'm only replacing one side though?
post #28 of 37 (permalink) Old 08-31-2010, 04:58 AM
Then get the Moog, Motorcraft, or TRW for that side only.
Or, just get a bushing set and a pair of ball joints - they're not that much, even for Moog joints and the poly bushings that SCP sells, for instance.
http://www.supercoupeperformance.com...spx?partId=609 for the bushings, at $70 (about the price of one control arm) and $31 each for the Moog K8477 ball joints. Be sure, while you've got the control arm out, to replace the strut rod bushings if you haven't yet (Motorcraft only, search for the #s here for the JustTheBushing kits.) Also, be worth replacing the lower shock bushing while the arm is out, just for grins'n'giggles (if you're chasing out a squeak or clunk).
But I'd do both - the other side is JUST as old, and is probably not in much better shape.
RalphP is offline
post #29 of 37 (permalink) Old 08-31-2010, 12:52 PM
Other side is in a lot better condition, and I know that has been replaced earlier than 3 years ago, now that I've looked through my receipts. Hopefully this week or next week, I'll replace the passenger side lower arm and ball joint assy and the driver's side strut rod bushings.
post #30 of 37 (permalink) Old 08-31-2010, 09:54 PM
Tailwind_91's Avatar
Just so I am not confused on this discussion.....
It looks to me like the pictures posted above are identifying a possible bad boot or ball joint on the "outer tie rod end".....(not the lower control arm).
Maybe I just missed the point, but it just seems like everybody is talking about replacing the lower control arm/bushings, etc....but, (I think) the pictures are identifying a possible bad "outer tie rod end".
Maybe I am just mis-reading the pictures...?
Tailwind_91 is offline
