sensa trac rear shock absorbers for mark viii - TCCoA Forums
post #1 of 11 (permalink) Old 06-07-2010, 10:07 PM Thread Starter
mybird_91's Avatar
Send a message via Yahoo to mybird_91
here is a link to scp, the question is... it says a must for coil-over swap but can i use these with the stock air bag set-up? mine are done for and this is the cheapest i've found.
http://supercoupeperformance.com/par...spx?partId=563
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #2 of 11 (permalink) Old 06-07-2010, 10:18 PM
Yes, you will be fine. The reason it says they are a must for the coil conversions is that most of the coil conversion kits come with front shocks, but no rear shocks, so you would have brand new fronts with the tired old rears if you did that. Also, just so you know, you can use any tbird/cougar rear shocks too, the only difference is that the upper mounts are a little different on the MarkVIII, so to run tbird shocks, just pull the mount out, burn the rubber out of it, and put it back in, then install the shocks like you normally would in a tbird.
post #3 of 11 (permalink) Old 06-07-2010, 10:30 PM Thread Starter
mybird_91's Avatar
cool thanks man
LT1 350
post #4 of 11 (permalink) Old 06-07-2010, 10:53 PM
Raptor22's Avatar
Those are good shocks, I had them on my 1989 Thunderbird before I switched them for Tokicos from an SC. Really solid for a "non-performance" shock. Decent handling and awesome ride quality.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #5 of 11 (permalink) Old 06-07-2010, 11:08 PM Thread Starter
mybird_91's Avatar
just ordered these and the screamin demon coil packs from scp.
hey raptor22, do the sensa tracs come with the top mount kit or do i need to search for those and do you know where i could find a deal on them if i do need to because my dr side one is shot.
LT1 350
post #6 of 11 (permalink) Old 06-07-2010, 11:35 PM
Raptor22's Avatar
They should come with them, but I am not completely sure. They were on the car when I bought it from the original owner who probably had a shop put them on. I know Napa Auto Parts carries them and they usually have pretty competitive prices. If not you can find them at RockAuto for real cheap.
Raptor22 is offline
post #7 of 11 (permalink) Old 06-08-2010, 12:07 AM Thread Starter
mybird_91's Avatar
thanks i appreciate the advice
LT1 350
post #8 of 11 (permalink) Old 06-17-2010, 01:58 AM Thread Starter
mybird_91's Avatar
grrr...... they sent front shocks not rear and they are the non air bag shock so they are no use to me. upper bolt that goes into trunk is way to skinny so hopefully bill at scp will make this right.
LT1 350
post #9 of 11 (permalink) Old 06-17-2010, 02:29 AM
When I bought sensa tracs from checkers they came with bushings and nut/washer for each shock. THey are good for the price what else can you say about that.
post #10 of 11 (permalink) Old 06-17-2010, 07:20 AM Thread Starter
mybird_91's Avatar
they are good for the price but i bought rear shocks and these are not the right ones. i'm not putting the wrong shocks on my car and they wouldn't work even if i wanted to.
LT1 350
post #11 of 11 (permalink) Old 06-18-2010, 02:56 AM
Oh yeah I gotcha
