Lowered my car, Rear End Too High, Do I need Endlinks? - TCCoA Forums
post #1 of 21 (permalink) Old 06-22-2010, 10:22 PM Thread Starter
Raptor22's Avatar
I lowered my car with the Eibach Prokit springs but the ass end still rides higher than the front, do I need shorter end links? What can I do to make it ride level?
You can see it real clear in this picture of my Ford fleet:
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #2 of 21 (permalink) Old 06-22-2010, 10:25 PM
Not sure if this is it or not but mine was setting a bit high after the swap, Then the 500 mile ride back to PA at the time the car was settled just right .
post #3 of 21 (permalink) Old 06-22-2010, 10:26 PM Thread Starter
Raptor22's Avatar
Maybe, its been probably 500 miles since I rebuilt my suspension with the Eibachs....
Raptor22 is offline
post #4 of 21 (permalink) Old 06-23-2010, 02:42 PM Thread Starter
Raptor22's Avatar
What else could it be? Should I just go get a couple bags of cement?
Raptor22 is offline
post #5 of 21 (permalink) Old 06-23-2010, 02:53 PM
Superduty's Avatar
I wish mine slanted that way. Mine has the same slant but from front to rear. It sucks.
Superduty is offline
post #6 of 21 (permalink) Old 06-23-2010, 03:23 PM Thread Starter
Raptor22's Avatar
Ouch.
Anybody have any idea what would cause my slant? I would prefer no slant. Maybe I could trade my springs for SuperDutys...
Raptor22 is offline
post #7 of 21 (permalink) Old 06-23-2010, 04:37 PM
Wait a 1000 miles then....if they don't settle, take out the spring Isolator.
post #8 of 21 (permalink) Old 06-24-2010, 11:06 PM
Stryker's Avatar
Mine looks the same way.... i also just removed my entire stereo which was quite heavy.
I love the flat low look and do not at all have any desire for a rake like your pic. I'm running the stock end links at the moment. i do have the SCP shorter one's in the tool box but have no idea how I put them on.... anyone wanna tell me. I can then let you know if it makes a difference. I'm just reworking the stereo and gonna put it all back in and then the car will be nice and flat once more. must've raised the ass end a full inch.
on a side note your front end looks very low almost like it needs some work.
Mods: The usual stuff... 3.73 Gears, J-mod, catless mandrel 2.5" true duals, Marauder Converter, Eibachs, Xcal2 and Phoenix Gold Audio, chrome 18's, etc. etc..
I joined the dark side...
2002 Mustang GT, FRPP Aluminator with Tork Tech MP112 intercooled S/C at 17PSI, with all the supporting mods.
Stryker is offline
post #9 of 21 (permalink) Old 06-24-2010, 11:19 PM
R8D-XXX's Avatar
This
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #10 of 21 (permalink) Old 06-24-2010, 11:58 PM Thread Starter
Raptor22's Avatar
Haha, the front end is lowered 1.5 inches, I like the lowering. The entire front suspension is brand new, including the subframe, and all control arms and sway bars.
Raptor22 is offline
post #11 of 21 (permalink) Old 06-25-2010, 12:13 AM
dDUBb's Avatar
Maybe the direction of the coil when you installed the rear springs if they face inboard they can raise the rear end higher, or one side higher than the other .. Ive seen it before.
dDUBb is online now
post #12 of 21 (permalink) Old 06-25-2010, 12:37 AM
kpthefatty's Avatar
I think its the wire wheels
kpthefatty is offline
post #13 of 21 (permalink) Old 06-25-2010, 12:40 AM Thread Starter
Raptor22's Avatar
I had a shop install them since I dont have a spring compressor and didnt feel like Jerry rigging them...
I will check it out, if that turns out to be true than I will go down there and talk to them about it.
Haha...
It was worse, I had whitewalls.
It kind of looks b.tchin' now.
Raptor22 is offline
post #14 of 21 (permalink) Old 06-25-2010, 01:24 AM
kpthefatty's Avatar
I don't know, I may have been tempted to stick with the white walls
After all, someone around here has to have the grandma car. I'm just messin with ya. I know you worked hard for those wires. Its a good lookin bird.
post #15 of 21 (permalink) Old 06-25-2010, 01:53 AM
CrystalPistol's Avatar
He's talking about trhe very end of the coil spring wire, it should set in the lower spring bucket on the outer side towards the rear tire. Should maybe be able to jack it and maybe twist if springs were short enough? At least look and see where the end is.
No, end links don't hold the car up.
CrystalPistol is offline
post #16 of 21 (permalink) Old 06-25-2010, 02:59 AM
Poly bushings?
post #17 of 21 (permalink) Old 06-25-2010, 06:56 PM
Bradone's Avatar
5 minute check. Disconnect the sway bar and find out. Not rocket science here.
Brad
[email protected] (engine/trans is stock)
Bradone is offline
post #18 of 21 (permalink) Old 06-26-2010, 01:05 AM
Traveler's Avatar
Its not the sway bars... did you have them put new spring isolators it it along with the springs? and if so, did they use Poly. When I put my Lincoln LCA in the rear of the car, I also put in poly spring isolators. And now its sitting up high in the rear as you describe. Thinking of taking out the new Poly ones and finding some used rubber ones in good shape at a salvage yard.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #19 of 21 (permalink) Old 06-26-2010, 02:52 AM
Bradone's Avatar
We were talking about sway bar end links holding up the rear. Did something change?
Brad
Bradone is offline
post #20 of 21 (permalink) Old 06-26-2010, 04:16 AM
Brad
Nope, check his original post. Just trying to find out what he did with his spring install.
post #21 of 21 (permalink) Old 06-26-2010, 07:10 PM Thread Starter
Raptor22's Avatar
Haha, hey it was one. She (the original owner) died and her daughter sold me the car, it was far gone but I pulled it back from the brink of grandma....
Thanks.
Thanks, I will check.
Originally Posted by Rodeo Joe View Post
Poly bushings?
I didnt replace them.
Originally Posted by Rayo View Post
how bout those hub dubs!..lol..jk
They arent hub dubs!
lol!
Brad
I suppose I could, I'll see what I find out.
Nope, using factory spring isolators, I actually replaced the front ones with poly and the front is low...
Thanks Joe, I appreciate the time and attention to my thread.
Raptor22 is offline
