creeking when i turn - TCCoA Forums
post #1 of 5 (permalink) Old 06-23-2010, 09:16 AM Thread Starter
i have a 93 tbird and just recently it starts to creek pretty loud when i turn the steering wheel either direction. i had most of the suspension redone about 4 years ago so depending on what it is i can get it replaced under warranty. also when i brake my car veers to the left. now ive changed the brakes and calipers twice already so could it possibly be the suspension causing it? thanks.
-David
16tbird93 is offline
post #2 of 5 (permalink) Old 06-23-2010, 09:37 AM
richuncle's Avatar
My car creaked pretty loudly while turning when my lower control arm ball joints were on their way out. Did you do the work yourself? I would recommend looking at all your ball joints, and seeing if anything else is loose. There is a sticky about different items to check.
richuncle is offline
post #3 of 5 (permalink) Old 06-23-2010, 10:33 AM
MAMN12 Posse Member
JeffTBird93's Avatar
I had both of those same problems. It turned out to be the control arm-to-frame bushing on the driver side. Sounded horrible when turning the wheel, and when you'd touch the brake, the car would pull that direction.
I ended up replacing the whole control arm. They sell Moog replacements at Advance pretty cheap that includes the control arm bushing, strut bushing, and lower ball joint. Just add a set of strut rod bushings while you're there and you'll be good to go.
Oh, and a realignment.
~Jeff
*signed off
JeffTBird93 is offline
post #4 of 5 (permalink) Old 06-23-2010, 12:28 PM
T6Rocket's Avatar
Driver's side LCA.
Brenda's Cougar did the same creaking, and pulled to the right under braking. Replaced the pass side lower control arm, and all was good!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 5 (permalink) Old 06-23-2010, 03:36 PM
1996Project-bird's Avatar
My friends car was doing that. Turned out to be ball joints covered under a recall (1996 avenger)
1996Project-bird is offline
