Lowered Springs - TCCoA Forums
post #1 of 12 (permalink) Old 06-23-2010, 11:01 AM Thread Starter
nbfiore's Avatar
Lowered Springs
Anyone have any experience with thesehttp://lightningmotorsports.com/susp...h/g-52942.aspx springs? Was thinking of getting these with the yellow Koni's shocks?
nbfiore is offline
post #2 of 12 (permalink) Old 06-23-2010, 11:29 AM
95xbird's Avatar
Im unsure of their quality but you can have Vogtland shipped to your door for 240ish. And those are great springs. What bothers me is that the site you posted doesn't tell you that shorter rear links are required for a 1.6 drop. I'd go with Vogtland again just because they are great springs and I believe to be proven many times here on this site.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #3 of 12 (permalink) Old 06-23-2010, 11:58 AM Thread Starter
nbfiore's Avatar
So if I were to go with the vogland would I still need the shorter links? It's been a while since i've done any kind of work on a car and even then they were mostly imports that I worked on.
nbfiore is offline
post #4 of 12 (permalink) Old 06-23-2010, 01:14 PM
95xbird's Avatar
Yes I bought mine from http://supercoupeperformance.com//Default.aspx Bill hooked me up. Good guy to deal with. Just email him. Check it out.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #5 of 12 (permalink) Old 06-23-2010, 05:14 PM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
you dont need shorter endlinks unless you have an aftermarket swaybar.
-John
MAMN-12 Fringe Member
94MN1246 is offline
post #6 of 12 (permalink) Old 06-23-2010, 05:55 PM
95xbird's Avatar
Is that right? I was told I needed them. Only in the rear though.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #7 of 12 (permalink) Old 06-23-2010, 06:03 PM
RESET's Avatar
I didn't use different links when I put the H&R springs on my car. Been working fine for several years that way. I think the H&R springs are only 1.5" drop though, maybe that makes a difference.
RESET is offline
post #8 of 12 (permalink) Old 06-23-2010, 06:14 PM
95xbird's Avatar
I doubt .1inch would make a differance. Im currently not running a bar in the back cause the slicks wouldnt clear. Ima bolt it back up and see if the links fit.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #9 of 12 (permalink) Old 06-24-2010, 09:12 AM
across281's Avatar
well let us know what happens cause im about to order the vogtlands 1.6in
across281 is offline
post #10 of 12 (permalink) Old 06-24-2010, 09:51 AM
MAMN12 Posse Member
JeffTBird93's Avatar
I've always run stock endlinks..? That includes Eibach, Intrax, and even when it was bagged. I'm running an SC bar in the back.
~Jeff
*signed off
JeffTBird93 is offline
post #11 of 12 (permalink) Old 06-24-2010, 06:34 PM
conversion02's Avatar
Lots of emotion on this topic.
See http://forums.tccoa.com/showthread.php?t=101659
conversion02 is offline
post #12 of 12 (permalink) Old 06-24-2010, 09:07 PM
95xbird's Avatar
Emotion for you maybe? idk. But thanks for the link. I still have yet to try this out. I have brand new stock links from before I bought the springs. When I get time I'll put them on and snap a pic.
Its slow, Really.
LS1 KILLER
95xbird is offline
