power steering. - TCCoA Forums
post #1 of 5 (permalink) Old 06-28-2010, 03:42 PM Thread Starter
richs1000's Avatar
Send a message via AIM to richs1000
power steering.
what kind of mant. should you do to the power steering system?
Rich
US Air Force
Oil Leak? No thats the frame lubricator.
richs1000 is offline
post #2 of 5 (permalink) Old 06-28-2010, 03:49 PM
A system flush and new fluid
post #3 of 5 (permalink) Old 06-28-2010, 04:14 PM
A periodic flush is the only thing I'm aware of. I'm not sure of the recommended interval, but I wanna say if you do it with your tranny fluid changes (every 30k) you'll be good.
post #4 of 5 (permalink) Old 06-28-2010, 04:16 PM
I was thinking, minimum 50k intervals.....
post #5 of 5 (permalink) Old 06-28-2010, 11:07 PM
30,000miles is what I recommend all day at work. I use only mercon 5 in my powersteering after having internal rack leaks with synthetic valvoline ps fluid and prestone ps fluid. I have also noticed less noise using the mercon 5 than any other fluid. The only additive I've seen work well in them is tx7. At work I use a machine that has a suction and pump to drain and fill the reservoir but at home I use some hose and turkey bastor with great success.
